4:10 Performance Gain
Old Oct 22, 2016 | 02:29 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Default 4:10 Performance Gain
What should I expect going to 4:10 rear in a stock 08 that now goes 12.7 @ 115? I need to overcome the driver deficiencies the 08 is saddled with.
M6 Z51
Old Oct 22, 2016 | 06:22 PM
Pitufina's Avatar
Pitufina
If you're not using sticky tires, which it doesnt looks like, the torque multiplication the gear change will provide it's just going to make matters worse. Get some good drag radials and learn how to max out the current combo, then think about the gear change.
Old Oct 22, 2016 | 08:32 PM
redbird555's Avatar
redbird555
Before you dive into gears you should try to get the car working as it sits. Unless you're at terrible high altitude that car is capable of much more bone stock. Realistically it should be in the low 12s trapping another 2mph or so. Adding gears to that is just. Going to make tbharder to launch. Get it working as it should first before adding gears
Old Oct 22, 2016 | 09:01 PM
Paratrooper307's Avatar
Paratrooper307
Gears make for snappier performance, but as others have said, it's going to make launching trickier. They will also require you to adjust your shifting. I'd concur with the recommendation to address tires and driving first, and look at suspension/alignment as well. Gears will do little good if those items aren't taken care of.
A side note-if you get the forced induction bug, you'll probably want to stick with stock gearing anyway.
Old Oct 22, 2016 | 09:40 PM
5knives's Avatar
5knives
Here is an excellent thread that may answer your question and help your mod path.
https://www.corvetteforum.com/forums/c6-tech-performance/3049605-best-mod-for-return-on-dyno-overlay-stock-headers-cam-fast-heads.html
Old Oct 22, 2016 | 11:32 PM
xBoostx's Avatar
xBoostx
Get the 4.10 gears and Micki Ts drag radials they will improve your driving skills much faster than with out them.
Old Oct 24, 2016 | 09:52 AM
Suns_PSD's Avatar
Suns_PSD
When you get 4.10 gears RPM Trans will tighten up the diff lock. You will actually get better traction off the line with the gear set.
I know it seems crazy and although experienced people told me it would happen, I didn't really believe them until I found out for myself.
Old Oct 24, 2016 | 03:35 PM
robz's Avatar
robz
With the manual (and the addition of 4.10 gears)you can launch @ a lower rpm to achieve same 60' and it will put less stress on the clutch.
But the overall best way to improve et is seat time.
Old Oct 24, 2016 | 08:30 PM
CMY SIX's Avatar
CMY SIX
lower fuel mileage, no top end,
Old Oct 24, 2016 | 08:48 PM
Pitufina's Avatar
Pitufina
No top end?
Old Oct 24, 2016 | 09:02 PM
Suns_PSD's Avatar
Suns_PSD
Yah, your theoretical top speed drops from 254mph to a pathetic 222mph. Good news is it gets there faster, but who cares? I drive at least 240mph everywhere I go.
Old Oct 24, 2016 | 10:20 PM
Unreal's Avatar
Unreal
Bahahahahahaha. No top end. Ahahahahahahahahaha. Comedy gold.
To 4:10 Performance Gain
