Ls3 with 1.8 rockers install
Old Aug 23, 2020 | 08:21 PM
  #41
Dave_in_VA's Avatar
Dave_in_VA
In terms of fitment I totally agree.
In terms of part specs I have no idea!
Old Aug 24, 2020 | 01:51 PM
  #42
Vette Threat's Avatar
Vette Threat
I installed 1.85 Yella Terra rockers on my 2010 Grand Sport with ARP rocker studs, comp cams pushrods ( I think 7400s ) and STOCK valve springs!! I could REALLY feel the difference and would shift ( manual trans ) flawlessly at 6700RPMS!!
I then added Z06 manifolds/exhaust on stock NPP muffs, Haltech CAI and a mail order ECS tune.
Without a cam, headwork or headers the car went 11.7@121MPH on a soft 1.8 60ft launch.
9 years and 60,000 miles later, the car still runs strong without a single hiccup.
Old Aug 29, 2020 | 10:03 AM
  #43
Dave_in_VA's Avatar
Dave_in_VA
Originally Posted by Turbo6TA
Looking at the photo of your engine, you have the Holley LS valve covers, but they are not the tall ones ... The valve covers you have look no taller than the stock valve covers.
That would explain a lot. I didn't realize there were std and tall versions. i bought mine used off this forum.
Old May 13, 2021 | 08:32 PM
  #44
BlueVetteGS's Avatar
BlueVetteGS
Wow this is incredible - I've a 2012 Grand Sport with GM Hot Cam and headers and have been thinking about doing a rocker upgrade, this thread has giving me the courage to seriously go for it my GS in NA. Thank you for this info.
Old May 13, 2021 | 08:36 PM
  #45
BlueVetteGS
I am bringing this 2016 thread back to life since I just replaced my stock 1.7 ratio stock rocker arms in my LS3 with a set of Comp Cams 'Ultra-Pro Magnum' 1.8 ratio rocker arms. (P/N 1678-16).
These full-roller rocker arms are Investment-Cast 8650 Chromoly Steel and the trunnion needle bearings are held in place with Circlips so they cannot fall out like the stock rocker trunnion bearings have been known to do.
The stock LS3 cam has a lift of .551 / .525 when the stock 1.7 ratio rocker arms are used ... When using the 1.8 ratio rocker arms, the cam lift increases to .583 / .556 (an increase of .032" on both the intake and exhaust)
I was worried that if I continued to use the stock LS3 valve springs, they would be very close to coil bind with this increase of lift, so I installed a set of PAC 1218 beehive springs. These springs are a drop-in replacement, so I used my stock valve locks and retainers .... The PAC 1218 springs are good for a max of .600" valve lift, so they are ok when used with the new 1.8 ratio rocker arms.
I also replaced my stock pushrods with a set of Brian Tooley 7.375" hardened rods. These rods are .025" shorter than the stock 7.40" rods, but I needed this slightly shorter pushrod in order to get the correct lifter preload.
My engine only has 21,000 miles on it, but since it's now 9 years old, I installed a new set of the 'hat' type valve stem seals too.
I haven't been to the dyno to see how much HP the extra valve lift added, but I can say that in my supercharged engine, it does run stronger ... I was hoping for maybe something like a 20 HP increase since my engine is boosted.
Sure, a cam change would be the best bet as far as a HP increase, but I don't want to go inside my engine ... I also don't want to go through the pain in the *** trouble it is to replace the cam in these cars.
1.8 Rocker Arms for rectangular port heads: . https://www.summitracing.com/parts/cca-1678-16
1.8 Rocker Arms for cathedral port heads: . https://www.summitracing.com/parts/cca-1677-16
Anyway ... Just posted this as a FYI for anyone here thinking about 1.8 ratio rockers
Thank you Turbo great info!
Old May 14, 2021 | 05:49 AM
  #46
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Your welcome ... My GS has not had any problems at all with these 1.8 ratio rocker arms and the valvetrain is very quiet.
No extra tuning is needed since all you are doing is increasing the cam's lift (cam duration remains the same as it was with the stock 1.7 rocker arms)
