Help with PTV clearance
I've never bothered to test PTV with a .040" head gasket and a stock cam but I would bet there's tons of clearance. It's not necessarily about how much lift the cam has but more about valve events. You can make a .550" lift cam have no PTV and a .700" lift cam have tons of room.
Regardless, why spend all the time and effoty trying to make your stock camshaft make more power when you can just change it out and make some real power.
2- don't want to spend the extra money for a cam
3- we can do the mod our self ....
4- don't want to loose the daily driveablity and reliability
5- can blaze the tires at will now , a cam will just make this worse
6- ok with the little gains that bolt on's provide
I can go on and on but I will stop now
Dave
Dave
1 - Willing to pull heads but not willing to take the rack out doesn't make sense
2 - If $400 for a camshaft is out of your realm, DO NOT MOD YOUR CAR (I know springs were already purchased from one of the other threads started)
3 - If you can do heads, remove the PS bracket (it's annoying)... you can do a cam, have faith in yourself. It's all just nuts and bolts.
4 - You don't have to, don't go buying a ridiculously large cam like so many do
5 - If you can blaze the tires don't bother cracking open the motor then anyway right?
6 - Not even worth the little/no gain you'll see from that tiny bump in compression
You're not the OP but guessing you're working with him. Good luck to you... I do this as my job and just trying to help guide away from someone wasting their hard earned money and valuable time on something that may get them little/no benefit.
