LSX454 All Blowed Up?
Have had the car for a couple months. Tunes always been alittle bad but it was always just Rich.
Ya nitrous, buuuuut I havent used it only tested when bought and it ran great. Havent used it since.
Now, I had the radiator break, got transmission fluid in the coolant and vis versus. replaced the radiator swapped the fluids. I added Prestone flush to clean the car out a bit. I removed the thermostat to more freely allow the coolant to move through the engine. Ran a few errands and at first I heard some squeaks but at the end of the couple errands it got bad.
I went home removed the belts and this is what it sounds like with no belts. My AC tensioner is bad and the engine tensioners also seem bad buuuuuut the engine shouldnt squeal like that. ESPECIALLY with no belts, so in my mind Im not trying to think as to what would be spinning and making that noise.
Whats the best plan of action here? Pull engine for rebuild or what?
Ignore the slow start up The engine has always done that and Im just too lazy to replace the starter when I am probably looking at a new engine.
