which wideband to use for E85?
Old Nov 19, 2016 | 02:36 PM
bp92gsr's Avatar
bp92gsr
Default which wideband to use for E85?
Im currently looking to use the Innovate ECB-1 which has the following features.
http://www.innovatemotorsports.com/products/ecb1.php
This is a result of me wanting a peace of mind filling up at the pump with low ethanol content E-85. I want to know what I'm putting in the tank while also having 4 separate readings on display all at once. Thoughts? Is there a better product out there? Thanks in advance!
Old Nov 19, 2016 | 09:07 PM
xBoostx's Avatar
xBoostx
Not sure of the particular product, have used the brand before and needed to wait till it warmed up before wide band reading so you can't tune cold starts.
I use E85 for years without any difference from tank to tank, I do know those that talk and never use it and ran their key board way larger then their tool box.
Old Nov 19, 2016 | 11:23 PM
bp92gsr's Avatar
bp92gsr
This will literally only serve as an indicator. Car has already been tuned.
Old Nov 20, 2016 | 12:10 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
If you're willing to install the flex fuel sensor from that kit, you may as well just get the GM one (it's probably the same honestly) and wire it to the ecu (and have it activated in the tune) so that this isn't a concern at all.
Old Nov 20, 2016 | 09:06 AM
xBoostx's Avatar
xBoostx
Cool so I guess you are getting that particular multi meter wide band cause you fear bad e85 can happen and you want to know? well if this is the case I have good news if the suspected fuel is less then 85% ethanol you wide band will detect that and you'll know rite away cause will start running richer with the additional gasoline contents.
Old Nov 20, 2016 | 10:10 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Are you running a flex fuel sensor currently?
And do you have dash logic? It can also report out the ethanol % if you're running a flex fuel sensor for the ECM.
Old Nov 20, 2016 | 11:07 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Can always add something like this. They make good stuff
http://www.zeitronix.com/Products/ECA/ECA.shtml
Old Nov 22, 2016 | 06:08 PM
GeneSch's Avatar
GeneSch
You will have to post up how to do this.
Old Dec 9, 2016 | 06:54 PM
bp92gsr's Avatar
bp92gsr
No I am not at the moment. The reason why I wanted to go with the 4 cannel innovate is because I also dont have a AF guage installed and wanted both.
I dont currently have a wideband or ethanol sensor installed at the moment which is why I want this 4 channel guage. I like how I can do four simutaneous readings on one guage. I'm not the type that like his cockpit filled with pillers of guages.
Yes! However, I need AF also which is why I wanted the guages I list in the OP.
Old Dec 9, 2016 | 07:53 PM
chpmnsws6's Avatar
chpmnsws6
I use the Ethenol gauge to monitor fuel temp and e %. The sensor that comes with it is a "gm" sensor and the gauges output will play happy with the GM pcm's.
Old Dec 18, 2016 | 05:19 AM
LeftLane Z06's Avatar
LeftLane Z06
AEM 30-4910 no sensor
30-4911 includes sensor
Old Dec 18, 2016 | 09:13 AM
KM177122's Avatar
KM177122
I'm running a flex fuel senor with it turned on in the tune. So, it automatically adjusts the parameters based upon ethanol content. As for AFR gauge I'm about to buy the AEM30-0333 X-Series OBDII wideband. Lastly, if you are wanting to be super safe, then you can get a fail safe setup like stated previously and you want to be monitoring the AFR of each engine bank.
Old Dec 18, 2016 | 02:58 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
The 30-0333's are nice and fast. Only negative is no analog output by default (can add the pins for it) if you happen to need it.
Old Dec 18, 2016 | 06:04 PM
KM177122's Avatar
KM177122
Can you please explain why I would need analog output?
Old Dec 18, 2016 | 06:32 PM
chpmnsws6's Avatar
chpmnsws6
For the ability to log with tuning software.
Old Dec 18, 2016 | 07:24 PM
sevinn's Avatar
sevinn
You can use it with hpt (not sure about efi live) without analog because it injects its signal over an obd pid.
You'd need the analog for most external loggers as well as dashlogic (that's the only reason I pinned mine).
Old Dec 18, 2016 | 09:05 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Dash logic mainly is the only thing I can think of
For HPTuners that model comes with a plug that plugs into the OBD port and feeds wideband info to HPT that way. Very fast way of doing it.
I believe EFI Live added support for that method also
To which wideband to use for E85?
Old Dec 18, 2016 | 09:14 PM
KM177122's Avatar
KM177122
Got it, thanks! That's why I was looking at getting the X-series that connects to the OBDII like you mentioned.
Old Dec 20, 2016 | 03:04 PM
MickVette's Avatar
MickVette
St. Jude Donor '13
I am in the process of returning a 30-0333. It would read full rich with any change in the O2 level around it. I had to borrow my friend's NTK to get my tune squared away. I removed the sensor and tried several free air calibrations but it will only read 20:1 or full rich.
After the free air calibration, I had the two different wide bands hanging together powered up and you can put a little propane and watch the AFR change on the NTK but the 30-0333 would go full rich any time the propane got near it. I pulled a third wide band (FJO) and it would read fine and show changes with a little propane.
I guess my 30-0333 is digital - full lean or full rich. HAHAHAHA!!!
I guess I got one of the bad one. I have read where many have had defective 30-0333 units but wanted a plug and play CAN bus wide band but never got that far.
Old Dec 20, 2016 | 07:19 PM
KM177122's Avatar
KM177122
Are you serious? I'm sorry to hear you had this issue. Can you please explain further? I still haven't ordered mine yet. LOL
