I change my rear wheels frequently between street and track set ups. Yesterday i was removing the driver side rear and 3 of the lugs were very difficult to remove. One of the wheel studs actually snapped (with surprisingly little effort). I spoke with a friend who educated me about the galling of threads being the cause of this. His suggestion, and what he does on his car, is add a bit of light grease to the threads before reinstalling. I just reviewed a lengthy thread about greasing wheel studs and came to the conclusion that about 50% think there is no issue with greasing studs and about 50% think that it is an issue. Assuming that the 50% that think it is an issue are correct, what steps can be taken to prevent galling in the future.
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
If you're using a torque wrench on the lug nuts, that's the cause of your problem right there.
I've gotten various amounts of crap for suggesting this in the past, but ever since I starting used a lug wrench and tightening them by hand I stopped having the problem. This approach has also helped several friends avoid having it too.
Galling is more common in alloys that rapidly form oxide coatings including aluminum titanium, and many stainless steels. The thin oxide can be removed during threading allowing the stud/lug to locally weld together. Heat is the primary factor. You can improve your odds by using anti-seize but, as indicated, this increases the torque (I back off of dry torque specs by 10%) but you can minimize the effect by NOT adding lube to the lug seat. Slow down the threading by threading by hand since a powered driver creates heat. Rolled threads are better since they're less likely to have friction inducing high spots from cutting. I swapped all of my lugs with ARP's last winter out of boredom. Sorry for geeking out.
DaveT
Very interesting info and I really like the part about 'boredom'...funny and understandable.
Brake dust is the corrosive - I've broken my share of studs too. I use a die to chase the dirt from the stud threads. Keep the threads clean and dry and always torque to 100 #-ft. Also, PB Blaster might be a good cleaner - worth a try.
You must have meant impact wrench (perhaps in conjunction with a torque stick).
A regular torque wrench isn't going to hurt anything. All it's doing is reporting the torque applied.
I don't get some using anti-seize or grease/oil, etc. There is little/no galvonic reaction steel to steel unless you're using aluminum lug nuts, which I've seen, but don't understand.
Torquing with a lubricated thread doesn't increase torque on the mating surfaces over a dry thread. 100 ft. lbs is 100 ft.lbs in both cases, but the difference is the lube greatly increases the clamping force which is the problem.
im looking at buying some new lug nuts now....is aluminum not a good idea?
I've seen them, just probably old school and don't trust aluminum as a wheel fastener. However, if you do use aluminum, you DO want anti-seize and reduce the torque. If it were me, I'd be in the range of 75 ft.lbs. with alum lug nuts.
Still doing research on galling. I have stock lugs (stainless) and stock wheel studs (not sure of material). My method of removing/installing the lugs is to break them loose and then remove with an impact gun. To tighten, I will use the impact gun to spin the lugs on, and then use a torque wrench to torque to 100 ft/lbs. Given that stainless is especially prone to galling (per article) is the best option to prevent this replacing the wheel studs with something else (if so, what)? Are ARP studs the best bet here? This seems like a problem that would have an easier solution!
I believe that the stock lugs are just regular nuts with a stainless cover over them, so the threads are not stainless. Aluminum sounds like a bad idea to me.
Galvanic corrosion isn't, normally, the issue. It's metallurgical bonding of similar metals. Rapid oxide forming metals are the worst (I don't recommend titanium fasteners unless it's mandatory). I agree on the torque value. The problem the lube creates is the excess bolt tension resulting in premature tensile failures when using dry torque values
Since you have to remove the hub to replace studs, you might as well just replace the hub instead. It comes with new studs. The hubs (aka wheels bearings) don't last forever. It seems the 100K mile area +/- 20K is the normal lifetime.
I change wheels often too. I trailer my race wheels to the track. I also remove wheels for lots of other reasons. I bought new aftermarket chrome lugnuts for the street and plain open ended ones for the race wheels. I hand spin lugnuts on/off and use a beam type torque wrench to tighten in 3 stages to 100 #'.
