Torque tube removal
Old Nov 24, 2016 | 02:50 PM
sprinter's Avatar
sprinter
Default Torque tube removal
If I have the engine out of a C6 Z06, can the torque tube be removed without dropping the gearbox/rear sub-frame?
Thanks.
Old Nov 24, 2016 | 06:49 PM
extrapilot's Avatar
extrapilot
I have not experience doing this job myself, but I would think that you should be able to with no problems, unless the rear bell housing looking part of the tube is to large to clear the body.
Old Nov 25, 2016 | 09:32 AM
Paratrooper307's Avatar
Paratrooper307
You'll probably have to drop the subframe/transmisssion or at least lower it to get the clearance you need to move the tube forward to separate it from the transmission with the way the tube is tucked up in the driveshaft tunnel. I've only done this from the perspective of a clutch replacement (engine in) so I could be mistaken, but I don't think the rear bell housing will detach like the front does.
Old Nov 26, 2016 | 04:13 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Thanks.
Everything at the back needs to be lowered as it won't clear the tunnel properly otherwise.
Old Nov 26, 2016 | 04:41 PM
timd38's Avatar
timd38
He is the master, believe him!
Old Nov 26, 2016 | 11:56 PM
sprinter's Avatar
sprinter
Thanks, guess I will drop the rear cradle then..
Old Nov 27, 2016 | 09:46 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It's easy
To Torque tube removal
