Front Fender Removal
Old Nov 29, 2016 | 01:35 PM
SuperVetteC5's Avatar
SuperVetteC5
Default Front Fender Removal
Is it necessary to remove the front facia in order to remove the front fender on a C6 Z06?
Old Nov 29, 2016 | 03:27 PM
08mojo's Avatar
08mojo
I personally have never removed the fenders, but I have seen pictures of the front fenders removed with the front fascia still in place.
Old Nov 29, 2016 | 03:54 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I've removed the fenders on a non-Z06 with the front bumper still on. It's a pain the first time because one of the bolts for the fender is under the corner of the bumper, but it was doable.
Old Nov 29, 2016 | 09:54 PM
russ472's Avatar
russ472
the fenders will come off without removing the facia. just remove the top screws that hold the top of the facia on.pull that edge out towards the engine. once it is a little loose, lift straight up. there is a clip that holds the facia to the fender between the hood and headlamp area. when lifting straight up, it should release and you will gain access to the hidden screw that holds the fender down.
To Front Fender Removal
