I was looking under the car while doing an oil change just eye balling the header install I'll be doing in a few weeks. I bought a set of AR headers from a member here a few months back just haven't had time to put them in. The headers are catted and came with sensors but from what I can tell the factory harness is not going to reach the plugs on the headers or cats. This would lead me to believe that you have to run extensions correct? I have heard yes and no but looking at it tells me I do. Anything specific about them or just order whatever is out there?
No... front and rears have different connectors but no difference between left and right. I would, however, always replace the fronts in pairs... haven't had rears in ages.
Yep I always use the same sensor that was in my OEM set up. Above comments are correct on tuning out your sensors but using used ones I would not try and might create issues. I've been down this road on a couple C5 header swaps. Just sharing my experience and a word of caution.
That is simply just not how an O2 sensor works. It either reads correctly or it doesn't. The car doesn't know or care which one you put in what hole as long as the plugs will connect to each other.
I have no idea what was going on with your C5 but it 100% without doubt was not because you switched the sides of the O2 sensors. Plenty of people do damage either the wiring or the sensor itself when removing and reinstalling.
Let me ask you this, have you ever installed a used set of O2 sensors on your car? If swap your front left sensor with your right sensor your car will not run correctly, trust me.
Are you talking swapping your left sensor wire with your right sensor wire ... then yes you are right
But if you are talking about swapping the left O2 sensor and installing in on the right side ... then you are wrong ... the car does not care , an O2 sensor is an O2 sensor ....
Dave
Hey Dave, yes I have been wrong before? Do you feel I'm placing mis information out here on the forum? Im sharing my experiences is it a matter of me being right or wrong then in your and Omegas eyes "I'm wrong". I digress.
Hey Dave, yes I have been wrong before? Do you feel I'm placing mis information out here on the forum? Im sharing my experiences I it's a matter of me being right or wrong then in your and Omegas eyes "I'm wrong". I digress.
No disrespect intended Brandon...sorry if you took it that way as it was not meant to be mean in anyway
just saying that there does not appear to be a right part number or a left part number , only one part number for both sides as they just vary the voltage of the signal that is sent to them
When i installed my headers i just removed them both from the pipes not even paying attention to which was the right and which was the left ....
I see a LS3 intake/filter in the photo and a C3 in your profile, so I'm assuming the question is about a 2008-2013.
You may not need extensions IF you can strip back the tape on the OEM harness far enough to reach the sensor connectors. I had enough length with LG headers, so take good measurements, since I gained somewhere around 14-18". You may need more or less with AR headers.
I agree. No disrespect. We are not saying that you are being malicious in your posting or denying you of what you believe to have happened. In your case the O2 problem was likely misdiagnosed. The car doesn't know which is left or right side. When removing things I don't account for which O2 came from which hole and do not know anyone who does. If you swapped yours back to the original sides and things worked out just fine there is a possibility that the connection at one point was poor inside one of the connectors.
I see a LS3 intake/filter in the photo and a C3 in your profile, so I'm assuming the question is about a 2008-2013. You may not need extensions IF you can strip back the tape on the OEM harness far enough to reach the sensor connectors. I had enough length with LG headers, so take good measurements, since I gained somewhere around 14-18". You may need more or less with AR headers.
Yes this is for my 2012 not my '69 in the sig. so you are saying you gained an additional 14" or so by cutting back the tap? Wow that's a lot! The AR headers locate the sensor down at the collector and since the factory location is up top that seems like a stretch! Does your LG headers locate the sensor in the same spot like my AR's in the pic?
I installed Hinson headers and the front harness reach after cutting tape. They barely make it. The rear sensors won't matter if you have them tuned out. I'm sure AR can tell you what extensions you need. Hinson sent extensions with my setup. I think 20", but not certain.
Like I said ( and did ) you'll probably want to tune them out, so you won't throw a code. The tuner told me they don't effect performance anyways one way or the other.
Computer doesn't care what sensor you're using . What matters is the wire is connected to the correct one and that there's nothing wrong with the sensor
Obviously swapping the wiring to the wrong side will cause issues.
It will be getting tuned after I install them, Ill have him turn the rears off. Ill go ahead and buy two extensions for the fronts just to ensure I'll have enough. I hate doing something simple like a header install and being held up on a part.
Thanks!
You need extension for the rears not the fronts, at least on my Z i didn't need fronts and i tuned the rears out. I have the same setup you have
