Dry to Wet sump?
Old Jan 19, 2017 | 01:56 PM
H8tulooze's Avatar
H8tulooze
Originally Posted by KENS80V
Thanks!
Old Jan 19, 2017 | 04:40 PM
5knives's Avatar
5knives
I have nothing to offer other than the request you post pictures of the Nova when it's complete.
Old Jan 19, 2017 | 05:00 PM
H8tulooze's Avatar
H8tulooze
Will do, this car should be a screamer with a LS9 at 700RWHP!!!
Old Jan 21, 2017 | 07:29 AM
ttbestas's Avatar
ttbestas
what you gonna do with oil level sensor?
im going from dry to wet.
dry sump doest have such sensor at all.
Old Jan 21, 2017 | 11:57 AM
H8tulooze's Avatar
H8tulooze
I dont need one, its in a Muscle car!
Old Jan 28, 2017 | 12:37 AM
H8tulooze's Avatar
H8tulooze
Well I ran into a snag, the LS3 crank sprocket (12556582) does not touch the key way (too short) on the crank. It will just spin, the factory one is to long because it hits the LS3 timing cover. The spacer from SPDC says " Do not use with LS9".
I wonder if I have to pin the crank all the way back?
Old Jan 22, 2021 | 11:23 AM
Tsmyth's Avatar
Tsmyth
How did the ls9 end up? I’m converting mine to wet sump now and ran into the same snags. Thanks.
Old May 16, 2023 | 10:19 AM
siemens03's Avatar
siemens03
no one ever figure this out? im at the same "snag"
Old May 16, 2023 | 03:55 PM
Tsmyth's Avatar
Tsmyth
I figured this out. Search for ls9 airboat. I took the crankshaft out and had it machined and re balanced everything.
