Weld wheel 15/17 combo
Old Dec 19, 2016 | 11:21 AM
C6vettegfw's Avatar
C6vettegfw
Default Weld wheel 15/17 combo
Hey guys. I got 325-50-15s for the rear and I'm going with weld 17x9s for up front. Just wondering what tire I need to use to prevent from getting the engine drag code... I know the tire height needs to be about a inch or so apart
Old Dec 19, 2016 | 11:53 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Just look up the heights for the tires that fit that rim. That's all anyone else can do for your answer.
Old Dec 19, 2016 | 12:19 PM
C6vettegfw's Avatar
C6vettegfw
I have Jody.... only thing I'm really seeing is a 275-40-17 and that's nearly 2 inches shorter then the 325-50-15.... just wondering if that will give me any codes?
Old Dec 19, 2016 | 12:30 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Probably will. Ive run up to 1.3 difference with no issues. Never went more than that. Doesn't somebody make a 275/45/17.. might be closer.
Personally, I prefer 18s in front, but that ship has sailed it guess.
Old Dec 19, 2016 | 12:44 PM
C6vettegfw's Avatar
C6vettegfw
NO it's not as I don't have them ordered yet. What 18 tire would you recommend.... I can order the 18x9.5 wheel that's no issue
Old Dec 19, 2016 | 12:49 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
No idea cause I run a narrower wheel, but again.. check heights... there must be something withing range.
Old Dec 19, 2016 | 01:23 PM
C6vettegfw's Avatar
C6vettegfw
I just had a good chat with Anthony at LG and he said it's no problem to use the 17x9 as long as I turn off all the driver aids... this is no problem for me anyway.
To Weld wheel 15/17 combo
