Adding Headers to a LS2 with 85k?
I was wondering if there was a consensus on whether or not it's a good idea to add headers to my vette (LS2) with 85,000 miles on it? Do you think it would cause problems, adding that power to it? The car runs very well right now, and I don't track it or drag. It's my DD that I enjoy going fast on the highway with from time to time. Just wanting to get some opinions before I go buy a set of headers, only to encounter more problems that normal down the road. I just want to have this car for a long time, and don't want to do anything to harm it. (she's my baby)
Only mods it has CAI and SLP loudmouth 2's.
Thanks!
You are not going to break anything ......
Dave
Don't think your being realistic from what I've read and watched on YouTube, gains are more like 35+RWHP and that's considerable seat of the pants enjoyment
NSF
It's a seat of the pants gain that you can more than feel ........change out that LS2 air cleaner and free up some more HP ....
Dave
http://www.superchevy.com/how-to/eng...itional-power/
Below is the paragraph that says the Kooks headers, high flow cats, and crossover pipe only showed a gain of 20 hp... Again , I'm not trying to argue the point, but just wanted to show where I got my information from.. WW
Here is there conclusion::::
Conclusion:When the C6 bolt-on thrash concluded and the DynoJet rollers stopped spinning, it was obvious that the LS2 engine responded in a big way to exhaust and tuning changes. A total of 40 horsepower and 38 lb-ft of torque was coaxed out of the engine with increases all the way across the power band. The combination of the Kooks headers and mid-pipe with high-flow cats led the pack with an outstanding gain of 20 horsepower and 20 lb-ft of torque. The large 1 7/8-inch stainless steel headers with 3-inch collectors effectively pull out the power, without sacrificing the low-end. Although the Corsa Sport Exhaust showed only modest gains with 8 and 6 hp/lb-ft increases, the excellent tone and looks of the system are in themselves worth the price. What aren't documented are the gains that the Corsa system will achieve as you bump up the power levels and the stock cat-back becomes a restriction.
If headers alone bring 20rwhp and the tune another 15rwhp (that's conservative I think) I'm going to be good with that because like you say its expensive. I have guys saying they gained a ton more than that also, so we will see when ever I get mine done
NSF PS I cant make any sense out of what they (SC)posted on numbers ??
NSF
.... If I'm reading and understanding the article correctly , they had to do Kooks 1 7/8 Headers,crossover pipe, high flow cats, and a Corsa exhaust, (plus a tune) to get the extra 40 hp gain... That's over $3,000.00 in just parts "not including $500.00 labor if needed" and a $450.00 tune to get 40 hp...
..I'm sure the LS3 would show a bigger gain because your starting with a more efficient motor/heads combo with more hp to start with, (but the OP has an LS2 engine)....I have heard many guys claim they feel alot more power from their cars (seat of the pants feel ) after doing mods , when later the dyno shows differently....Last edited by WW7; Dec 28, 2016 at 05:50 AM.
Thanks!
