LS2 bolt ons and tune dyno sheet
I have an 05 ls2 non z51 6 speed.
I added Hinson 1 7/8 long tube headers with x pipe(no cat), Corsa/volant cold air intake(the one with a huge housing and scoop in the bumper), and radically ported ls2 intake mani from peakspeed. And intake mani was installed right before the tune.
Performance specialties in Glen Burnie, MD has a great reputations with LS engines so I gave it a shot. I know every car is different, and every dyno is different, but I feel like I got a pretty low number.
I'm about to do oil catch can and 160 t-stat next week, but I'm not sure if that's gonna do anything at all. Tuner told me along the lines of "Your car is not really taking the timing, I suspect most likely due to pcv pulling oil. " So he suggested me an oil catch can. He said once it's installed, he will take the car to the street to see if my car takes some timing and if it does he will dyno again.
That's pretty much what I got. I know peak number isn't everything, but it seems very low. I checked the compression when I bought the car and I had it for 1500 miles and I didn't drive hard. I put 93 octane gas always from top tier gas station. Any suggestions, comments or concerns? I greatly appreciate your time.
-max
-max
No the lower line is the base dyno with all the mods already.
Yeah, friend of mine with similar mods putting down close to 395 if I remember correctly. And I see bunch of dyno videos and sheets online with similar mods putting down a lot higher than mine.
I'm not gonna lie, it does accelerate smoother, but peak number just isn't there. Anyone has any suggestions?
Thanks again in advance.
-Max
-Max
I'm also wondering since new manifold was installed right before the dyno, I'm wondering if pcv oil pull was even an issue? I thought that was for like intake mani oil build up. NO?
Any more suggestions? Thanks
-Max
Tuning alone on the stock motor should yield in the 362rwhp/362rwt range.
The headers should have added about 25hp, and the ported intake another 10hp over the base numbers. The Cold air intake saves you power, does not add it, so when the car is on the dyno with the hood open and fan blowing into the engine bay, your not going to see any HP lose from hot air going into intake instead.
The fact that is blowing oil into the system and why it pulling timing due to the knock sensor, makes me wonder if you have other problems, such leaking valve seals or the motor/piston rings too worn instead.
Have you done a compression test on the motor, and where the valve seals check/replaced if needed. Spark plugs, what did the look like, since if they are sooty as hell, you got a oil leak problem into the cylinders that needs to be resolve now.
Also, what was the base line dyno pull before you started adding mods???
As for the catch can, it will save from a touch of oil from making it to the cylinders at full tilt, but the OEM system already has baffles on both the valve covers and valley cover, so it should not be dumping oil into the intake manifold to the point that is causing the motor to pull major timing isntead.
Yeah I did the compression right before the purchase and I don't remember the number but they were very even across the board. Spark plug wires are new and spark plugs were fine I believe. (Honestly I don't remember paying too much attention to spark plugs) I can pull them out next week and check.
I'm baffled by the numbers too. My tuner told me that a lot of cars been making 30 to 60 whp less than some other dynos. So..., I'm gonna take it to track and see if my time and trap speed is good. Besides the oil catch can, checking the spark plugs and maybe a t-stat, I'm gonna wait it out til I run the car at the track.
Any more suggestions will be appreciated. Thanks to everyone that is giving me any suggestions.
-Max
The auto has more drive line lose, and could explain your lower numbers.
Hence stock, the M6 makes 350rwhp/350rwt, while the auto with higher drive line lose ends up around 335rwhp/335rwt instead.
Also, need to see the graph for the pull to verify that we are talking ASA number, or if actual output for your altitude instead.
Read the ASA number compensates for the altitude lose if you are not at sea level, and give the HP number if the car was running at sea level instead.
-max
We will baseline it and if all is well it will be $75. If we tune it then you are looking at $400. We have our Dynojet 224 on site.
