how does a cam effect boost
Old Jan 28, 2017 | 05:32 PM
protree's Avatar
protree
Default how does a cam effect boost
Say stock bottom LS3 just bolt-ons headers ect.
boost is say 8 lbs and you stick a say around 228-236 600ish lift 114lsa cam in. Yes I know this isn't the best blower cam but just role play for a moment. how would this cam effect boost if nothing else changes. Would boost go up, stay the same or wont effect. I know no one came say for sure but I'm just asking a guest -a -mint of your opinionThis is with a supercharger.
Thanks guys
Old Jan 28, 2017 | 06:23 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Anything that makes air flow easier will reduce "boost". Boost is just a measure of restriction. You're shoving air through the engine, it backs up, boost is that back pressure basically
Make air flow better, less back pressure, less "boost", same or more airflow.
Old Jan 28, 2017 | 07:46 PM
xBoostx's Avatar
xBoostx
Makes engine more efficient will make more power with less boost by packing the cylinders better.
Old Jan 28, 2017 | 07:55 PM
CI GS's Avatar
CI GS
^^^^^^^^^ This is an exact, concise answer to your question as to how a cam will effect boost.
If you're also asking for a guesstimate of what boost you would make with that cam in an LS3 with headers, which is currently making 8psi of boost with a stock cam, I would guess somewhere around 5-6 psi. But, it will still make more power (since I'm guessing, I would say maybe 50ish?) with that cam than the stock one at that lower boost. Then all you need to do is pulley down from there
Old Jan 29, 2017 | 06:43 PM
protree's Avatar
protree
Thanks guys that's just what I needed to know.
To how does a cam effect boost
