Ls7 build
Old Jan 28, 2017 | 06:05 PM
badazz81z28's Avatar
badazz81z28
Default Ls7 build
Does anyone know if replacement LS7 blocks come ready to assemble? If a buddy gave me all the internals to an ls7, can it just assemble it?
Old Jan 28, 2017 | 08:02 PM
rkj427's Avatar
rkj427
Pro Mechanic
Blocks typically have cam bearings installed and main caps bolted in place. Rest is usually transferred over or replaced during build.
Old Jan 28, 2017 | 09:34 PM
Brandon619's Avatar
Brandon619
I agree with rkj427, personally I would not throw old LS7 rotating assembly in a new LS7 or used LS7 block for that matter. The LS7 crank is stout but I would do some forged pistons and nice connecting rods.
Old Jan 28, 2017 | 11:28 PM
badazz81z28
^^whys that?
Old Jan 29, 2017 | 12:21 AM
southspeed's Avatar
southspeed
I would put a set of replacement forged pistons in it but I wouldn't give up the ti rods. That way you can boost it or spray down the road without much worry.
Old Jan 29, 2017 | 10:03 AM
badazz81z28
Would I have to rebalance everything?
Any other inputs on putting the parts in a new block?
Old Jan 29, 2017 | 12:58 PM
Brandon619's Avatar
Brandon619
Originally Posted by badazz81z28
^^whys that?
Why, because when you put the time, money and effort towards a build I would want it to be fresh. Yes would I use the existing LS7 crank, have that micro polished and balanced. I'm not sure if I would use the factory TI rods depends on budget and I would definitely use some light weight forged pistons. Contact any reputable engine builder and tell them your plans and I'm willing to bet 98% of them would advise on new rods and pistons. Again this is my opinion and I have some experience on building a motor, not great experience but I've spec'd a motor before.
Old Jan 29, 2017 | 10:55 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
The correct answer is - sort of.
Here's exactly what I've done a several times starting off with a new block and used internals:
- buy new stock piston rings, new main and rod bearings as well as new main and rod bolts
- have the rotating assembly measured and checked out because even something coming from a running motor can occasionally have issues
- if the rotating assembly parts all came from the same engine then you could probably get away with not having it balanced, but if even one piston or rod came from somewhere else I'd recommend it
- buy and install a new rear main seal as well as the one for the front timing cover
- start bolting everything together
To Ls7 build
