P0717 code on Corvette C6 trans problem
Hi,
Ive got a 2005 Corvette C6 Coupe with an Automatic transmission.
The reverse is fine but on D DRIVE the car starts of on a high gear (limp mode!?)
With the Snap-on diagnostic Ove got the code P0717
Is there anyone that know where to start, to kill this problem?
Where is the sensor located to start with?
This car got really low milage.
Hi,
OK, i can just find one on the rear diff? I think that one is for the cluster?
Ive alsow had the P0315 code on the engine (crankshaft position sensor not releraned)
But that one i have releraned, but the tranny problem P0717 is still alive 0=/
didn't explain that very well.internal transmission speed sensor is located on side of transmission case extension.sometimes an issue with harness plug at sensor or speed sensor dead.check page 7-136 of the 05 factory service manual item 36
