Need X Pipe info.
Old Feb 7, 2017 | 11:19 AM
MLRS's Avatar
MLRS
Default Need X Pipe info.
Lack of knowledge on this subject takes me to ask you guys the difference of an OEM X Pipe of a 2009 coupe vs an aftermarket X Pipes such the Borla x-pipe-borla-2009-2011-c6. I'm asking because I'm getting ready to install a BB bullets axle back and the 1/4 insulated Tunnel plate and since I'll be removing the OEM X pipe why not update it.
Old Feb 7, 2017 | 04:44 PM
cstapp99's Avatar
cstapp99
The earlier C6s had an H pipe. In either 09 or 2010, OEM changed to an X-pipe mid section. From what I can see in looking at the design in the X pipe on my 2010, it's not a bad design. Looks like it should flow pretty well. Some of the aftermarket X pipes are 3" whereas the OEM is 2.5" on the non-Z cars. Other than that, no real big difference in my opinion. The big difference comes in forward of the X pipe should you get the bug to add long tube headers. That's where the big gains are over OEM.
In case you were wondering - the B&B (Billy Boat) long tubes mate directly to the factory mid section X pipe and eliminate your cats.
