What Fuel rail fitting ?
Old Feb 10, 2017 | 09:51 AM
VetteArts's Avatar
VetteArts
Default What Fuel rail fitting ?
What Tee fitting would suit the fuel rail to connect a fuel pressure gauge?
Kept looking but not sure what's the right one.
Old Feb 10, 2017 | 09:56 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It's a -4 AN fitting I believe
Old Feb 10, 2017 | 11:53 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
OP, get a 4an to 1/8npt fitting. A straight one will work fine but if you want to read it on top get a 90.
Old Feb 10, 2017 | 04:28 PM
timd38's Avatar
timd38
If you have stock fuel rails, where do you put it?
Old Feb 11, 2017 | 07:22 PM
klwehunt's Avatar
klwehunt
Close to the firewall.
Old Feb 11, 2017 | 08:37 PM
sevinn's Avatar
sevinn
You either run a hose off the test port or just put it there.
Old Feb 12, 2017 | 10:58 AM
KENS80V's Avatar
KENS80V
This style is popular. As mentioned earlier 4an to 1/8"npt. With the option of a 90 degree elbow. Almost every gauge manufacturer however will warn you (or have a disclaimer) mentioning not to attach it directly to the fuel rail/engine due to vibration. The correct way is to isolate it with a hose and mount it on your firewall. This is especially true with fuel pressure transducers.
http://www.ebay.com/itm/CHEVY-LS1-LS...-/260673352895
To What Fuel rail fitting ?
