Help with brake upgrade
Can I use a larger rotor with the stock calipers, if so what size and what else will I need?
I really like the looks of the 2 pc rotor, Southern has a 4 pc set for around $1000, are there any other vendors that have comparable prices?and I would like to customize the hub color to red or silver.
SS brake lines of course.
Would like to do a powder coat exchange with my calipers.
Any better ideas?
The base brakes will still out break the base tires(get the tires to stop spinning and kick in the ABS system), and just upgrading the brake system without improving the tire grip as well, just means that you will just need less break pressure to get into the ABS system when the tires lock up instead.
So before you do anything, get the brake fluid power flushed, to replace the old moisture saturated fluid with new clean fluid to begin with.
Hence the brake fluid on the vet, should be replaced around every 3 year, or if you are using the car for autocross or road coarse event where you are getting the brake fluid close to, or over it boiling point during such, the change the fluid out afterwards.
If such is just for show, then bling away instead.
http://www.knsbrakes.com
