wire connector help
Old Feb 13, 2017 | 08:52 PM
rabrooks's Avatar
rabrooks
Default wire connector help
so I have two wire connectors that I'm not sure where they connect. These are on the passenger side of the engine bay and adjacent to the ac compressor. I know 1 of them is for the ac compressor. not sure about the other. The connectors are along the harness section that runs along the frame rail just ahead of the fuse box. you guys helped me on my previous wiring question. Hope you can do it again.
Old Feb 13, 2017 | 09:10 PM
Unreal's Avatar
Unreal
Could be outside air temp sensor, or horn.
Old Feb 13, 2017 | 10:11 PM
rabrooks's Avatar
rabrooks
I have both of them hooked up. The connectors in questions are closer to the fuse box and AC compressor.
Is there a connector on the radiator or AC condensor
Old Feb 13, 2017 | 10:32 PM
Unreal's Avatar
Unreal
No connector on condensor. Could be AC pressure switch which is over there.
Old Feb 14, 2017 | 07:14 AM
rabrooks's Avatar
rabrooks
I deleted my AC. So are there two connectors that go to the AC compressor.
Old Feb 14, 2017 | 07:26 AM
Unreal's Avatar
Unreal
No, one to compressor, and one to line on the pressure switch. So not really to compressor, but to the ac system I guess.
Old Feb 14, 2017 | 09:18 AM
rabrooks's Avatar
rabrooks
Ok great. Guess that's why I can't find the connector location. I removed the compressor and the AC lines and blocked off the opening at the firewall. Thanks for all your help.
Anyway, I started the engine last night for the first time and I had no codes.
Now to get it to the tuner. should be close to 625 rwhp with stock intake, throttle body and injectors. has cam, AI heads BTR springs, LG front to back, and Haltech CAI, Katech red oil pump.
To wire connector help
