Z06 Front Camber... remove A-Arm Washers ?
Old Feb 19, 2017 | 01:24 AM
NTMD8R's Avatar
NTMD8R
Default Z06 Front Camber... remove A-Arm Washers ?
I am preparing my '08 Z06 for Autocross.
I have replaced the shocks, front sway bar,
and am going to run Hoosier A7 tires, in Class SSR.
I did an alignment, but I couldn't get as much front Camber in as I want.
I could only get -2.0 on each side.
So, could I remove 1 or 2 washers from the upper A-arms, to
allow for more Camber ? (There are 4 on each bolt).
Has anyone done this ?
Any problems with doing it ?
Old Feb 19, 2017 | 07:34 AM
timd38's Avatar
timd38
You replace the eccentric lower bolts with fixed bolts and blocks and the put studs on the uppers and use old style shims. Sounds counter to what you need, but you pick up adjustment doing it. Several options out there.
I bought this one.
https://www.corvettemods.com/C5-C6-C...FcK1wAodGCsKgA
This one used washers, but shims are easier to use.
http://www.zip-corvette.com/05-13-c6...tment-kit.html
Old Feb 19, 2017 | 11:22 AM
rabrooks's Avatar
rabrooks
Yes you can. Your alignment shop should have done that. You can't just pull out washers without a realignment though. I try to run my eccentric all the way out and then adjust with washers to get very close. Then adjust the eccentric to dial in. That way I get the widest track possible. Plus I run 3/8" wheel spacers for just that little extra.
You can also use the washers to adjust for max caster. Use more washers in the front of the upper a arm and only one in the rear of the upper a arm.
Old Feb 20, 2017 | 01:40 PM
Suns_PSD's Avatar
Suns_PSD
You can maximize camber and castor by removing all washers and then inserting 1 washer under the rear arms of each A arm only.
Old Feb 21, 2017 | 06:39 AM
sccaGT1racer's Avatar
sccaGT1racer
Turn your eccentrics to get the widest stance then adjust with the shims on the uppers.
Old Feb 21, 2017 | 11:46 AM
NTMD8R's Avatar
NTMD8R
GT1,
my problem is that I can only get -2 as the widest.
So I don't need to add shims; I need to remove washers.
Which is what I'm going to do.
Old Feb 21, 2017 | 01:46 PM
sccaGT1racer
GT1,
Exactly
Old Feb 21, 2017 | 05:01 PM
timd38's Avatar
timd38
If you remove the eccentric and replace with a locking plate and bolt, you can get slightly more than by just removing the washer on the upper arm.
Here are some recommend specs.
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
To Z06 Front Camber... remove A-Arm Washers ?
