30 more HP
Old Feb 19, 2017 | 09:06 AM
Last 1's Avatar
Last 1
Default 30 more HP
Will a electric water pump /radius rod mod for ls 3 intake/ electric cut out get me there. stock bottow end ls2 with CNC LS3 heads / ARH 1 7/8 header /stock intake/kaotic cam. the car made 509hp on a dyno jet thanx for the info
Old Feb 19, 2017 | 09:13 AM
irok's Avatar
irok
dyno it and find out
Old Feb 19, 2017 | 10:56 AM
Brandon619's Avatar
Brandon619
Bumping up your compression with a thinner head gasket (.030) and E85 will get you there. Cutouts might net you 5-8 ponies and a EW pump will be around 10 ponies. Bumping up your compression will net you over 20 rwhp with a .030 head gasket depending on your PTV clearance, if your heads are stock/not milled.
Old Feb 19, 2017 | 10:58 AM
z06scentair's Avatar
z06scentair
http://sdparts.com/i-23849192-nitrou...FQe5wAod4y0C8A
Old Feb 19, 2017 | 11:13 AM
Brandon619's Avatar
Brandon619
^^ Now there is someone with the answer, nitrous I love it. I've been debating going this route.
Old Feb 19, 2017 | 11:35 AM
z06scentair
https://livestream.com/MotorManiaTV/2017LO8
Old Feb 19, 2017 | 11:36 AM
Last 1's Avatar
Last 1
keeping it N/A friend . did u fixed your problem with your lifters
allready milled .30
Old Feb 19, 2017 | 11:49 AM
z06scentair
allready milled .30
.0003" of added clearance
LS2 original = .8423"
Johnson 2110 = .8420"
New PSI = -10psi
Old Feb 19, 2017 | 03:11 PM
Suns_PSD's Avatar
Suns_PSD
I though Katech had dynoed the electric water pumps and found them to gain essentially no hp gain? Anyone know the entire story?
The radius bars are going to give you between 10-18 rwhp depending on the rest of your mods.
Old Feb 19, 2017 | 08:32 PM
CMY SIX's Avatar
CMY SIX
VERY very hard on a motor!
Old Feb 20, 2017 | 10:55 AM
LEAVINU's Avatar
LEAVINU
I gained @7rwhp (peak) with an EWP when I was H/C LS2. I know because I pulled the EWP a few months after and lost this power. The pump had shorted and left me stranded so I went back to mechanical.
Old Feb 21, 2017 | 12:52 AM
KW Baraka's Avatar
KW Baraka
Bumping up your compression with a thinner head gasket (.30)........
Uhhhh.......no such thing.
On the other hand, there are a lot of head gasket brands that do .030" gaskets.
BTW, seeing that with the stock LS3 the piston comes about .005" above the engine deck at top dead center, an .040" head gasket (.035" quench) would be a much better idea for a street driven car; .025" of quench is bit 'lean'......
KW
Old Feb 21, 2017 | 08:44 AM
Brandon619's Avatar
Brandon619
KW
You caught my typo? Thank you for putting me in my place.
Old Feb 21, 2017 | 10:07 AM
xBoostx's Avatar
xBoostx
I believe the answer to your question is yes it should add at list 20 rwhp.
Old Feb 21, 2017 | 10:20 AM
xBoostx's Avatar
xBoostx
Funny I had one of those expensive beautiful ewp in my 06 gto and had circulation problems with it though I figure out the problem and fix it I just couldn't get rid of it fast enough, I believe the horse power loss is actually a positive security/reliability trade-off, hard to depart from old faithful.
To 30 more HP
