High quality P/S hose??
Old Feb 20, 2017 | 10:30 AM
demon340's Avatar
demon340
Default High quality P/S hose??
I've got the common to C6 leaking high psi P/S hose. All I have been able to find is house brands, sangsun ( china) or Edelmann from napa, autozone and the rest, I did find a Gates unit, so I'm leaning towards the Gates at this point. Is there a preferred hose part number or brand I'm missing? Thanks
Old Feb 20, 2017 | 10:48 AM
LEAVINU's Avatar
LEAVINU
I've got 81k miles on mine and have not experienced this. Can you elaborate on this 'common' leak?
Old Feb 20, 2017 | 07:53 PM
demon340's Avatar
demon340
Well maybe not very common, but in my research it seemed like this was a known problem with even some very low mile C6's having faulty P/S high psi hoses. My car just turned 63k and is a 07.
Old Feb 21, 2017 | 01:53 PM
irok's Avatar
irok
just buy the GM hose that lasts forever
Old Feb 21, 2017 | 05:06 PM
torquetube's Avatar
torquetube
It's probably more accurate to say that C6s with power steering fluid leaks are usually leaking from the pressure hose (as opposed to the return, or the rack, or the pump).
Old Feb 21, 2017 | 05:17 PM
timd38's Avatar
timd38
I made one out of steel branded Teflon. Less money and works great!
Old Feb 21, 2017 | 05:19 PM
timd38's Avatar
timd38
They changed the line in 2008, I think, and made it about 3 times as long. Not sure what the problem was, but they did leak and GM was fixing them for free.
Old Feb 21, 2017 | 09:04 PM
CMY SIX's Avatar
CMY SIX
and I can't find the "all ears" I love to hear about these "common problems" I've never had, 06 mn6 LS2 400rwhp 82.000 miles
Old Feb 22, 2017 | 12:51 AM
demon340's Avatar
demon340
what can I say, just got the car a month ago, first vette. Knew it had a leak when I checked it out, thought it was P/S fluid but wasn't sure. Checked this forum and others and most of what I was seeing pointed to P/S high psi hose on C6's, I think the hose was a problem area that's why the replacement differs from the original.
Old Feb 22, 2017 | 10:28 AM
timd38's Avatar
timd38
That is how i looked at it!
To High quality P/S hose??
