Black cylinder 7?
Old Feb 20, 2017 | 09:17 PM
jusmillz's Avatar
jusmillz
Default Black cylinder 7?
Heard a tick that increased with rpm range, so i assumed it was lifter. So i pull the driver side head and cyl 7 spark plug had oil all over it, and also the cylinder was more black than the rest. Also it is a small chip missing off of the head of cyl 7. You can see the diff circled in red. What in the world is going on here?
Old Feb 21, 2017 | 03:37 AM
phipp85's Avatar
phipp85
What did the #7 plug look like? No misfire codes?
Old Feb 21, 2017 | 03:43 AM
jusmillz's Avatar
jusmillz
The plug was black work oil residue, the car had no codes or symptoms, just the slight tapping noise that increased with rpm
Old Feb 21, 2017 | 07:43 AM
CI GS's Avatar
CI GS
What does the piston look like? Is that missing piece lodged in it somewhere? If so, that would explain the tapping noise.
I'm going to go out on a limb and say that given that you have oil pollution in that cylinder, oil is either getting past the valve seals or the rings. Oil in that cylinder would effectively reduce the octane threshold, so that cylinder would knock from pre-ignition (maybe that was the tapping noise?). Any sharp edge in a cylinder will run the hottest and would be the first cause of pre-ignition, and pre-ignition will quickly destroy that sharp edge. That's why race engines have everything in the combustion chamber smoothed nicely.
That pad has the corner broken off right next to the exhaust valve, which would be the hottest area in the CC, so maybe that caused it?
There's also appears to be some nicks above the intake valve in that photo and the pad seems like it's indented slightly, right below the spark plug. Looks like something small was rattling around in there. Maybe it went out the exhaust? Check your piston carefully. Maybe clean it off with a scotch brite pad and WD40 or brake cleaner so you can get a good look at it.
Old Feb 21, 2017 | 10:56 AM
rabrooks's Avatar
rabrooks
That cylinder definitely ingested something small. Either it messed up cylinder wall or it bent a valve just enough to not seat well. If I had to guess, I'd say it ingested part if the top ring and that may be where the oil is coming from
Post pics of the cylinder wall and piston top.
While the head is off you can soften all the hard corners of the combustion chamber by hand with some 220 grit sand paper just enough to take off the sharp edge. You will probably lose less than 1 hp. That will reduce the hot spots thus reduce knock, thus reduce timing retard. End result, more power under load.
If you decide to have the head decked and trued or go with a thinner head gasket for more compression, you definitely want to soften those edges
I know, you wanted to know what time it was and I told you how to build a clock. Just throwing info out there for less knowledgeable enthusiasts to learn from.
Old Feb 21, 2017 | 03:46 PM
jusmillz's Avatar
jusmillz
Finally lookee deep enough into cylinder 7 and found this.....
now i know this is a problem. So what are my next steps ? Swap the piston out and work on the heads call it aday or am i in for a long journey?
Old Feb 21, 2017 | 05:22 PM
z06scentair's Avatar
z06scentair
Too many unknown variables for anyone other than yourself to make a judgement call on that one.
If that cylinder wall is ok, then yes one could simply sway the piston and move on.
Old Feb 21, 2017 | 07:26 PM
CI GS's Avatar
CI GS
You running nitrous on that motor? That looks like the typical ring land lift from not enough ring gap for nitrous?
Old Feb 21, 2017 | 07:55 PM
xBoostx's Avatar
xBoostx
Power adder looking combustion damage just replace with new piston and new rings inspect the valves on that cylinder make sure are not bend put everything back and you are back in business unless you deem time to forge up.
Old Feb 21, 2017 | 08:15 PM
jusmillz's Avatar
jusmillz
headers, ecs1500,and meth.
Old Feb 21, 2017 | 08:16 PM
jusmillz's Avatar
jusmillz
i pray it can be as smooth as this.
Old Feb 21, 2017 | 08:24 PM
rabrooks's Avatar
rabrooks
Just a note for the future. Don't run cheap gas. Tell the truth. Are you running 87 octane gas. If so, you can see how it really matters which gas you choose. Not saying that's the problem but it is common on cheap gas.
new piston and rings and check the intake and exhaust valves and push rods of that cylinder. Good to go.
Old Feb 21, 2017 | 08:26 PM
z06scentair
I literally spit my drink allover the place.
Old Feb 21, 2017 | 08:31 PM
rabrooks's Avatar
rabrooks
LOL, I hope it wasn't something good like Crown or Gentleman Jack
Old Feb 21, 2017 | 08:40 PM
jusmillz's Avatar
jusmillz
Had the car 5 years always put 93 in the tank nothing below
Old Feb 21, 2017 | 08:41 PM
jusmillz's Avatar
jusmillz
lol i needed this laugh
Old Feb 21, 2017 | 11:39 PM
bmfvette's Avatar
bmfvette
Just the **** that happens to stock bottom ends with power adders. Ring land cracking is a common failure.
To Black cylinder 7?
Old Feb 22, 2017 | 07:33 AM
xBoostx's Avatar
xBoostx
I don't see any damage to cylinder wall and the head is ok just check the valves.
Is why I like heads and cam won't get as much power but stays on the road.
How much boost?
Old Feb 22, 2017 | 08:00 AM
stew1100's Avatar
stew1100
Is that piece part of the ring land of the piston.
If so how would it get into the combustion chamber without damaging the cylinder wall?
Old Feb 22, 2017 | 09:22 AM
z06scentair
Went straight out the exhaust, suck and blow
