Bottom End HP Limits
Old Feb 23, 2017 | 09:32 AM
Don4220's Avatar
Don4220
Cruising
Default Bottom End HP Limits
Hello Corvette Mechanics,
I have a 2012 GS (LS3) with a supercharger, blower cam & cam kit, high pressure Mellings oil pump, damper, direct drive belt sys pushing around 750 HP at the crank & 590 RWHP. I am thinking of installing a 100-150 Nitrous system. This is a show car with some street time NOT a race car, so the nitrous will only be used on rare occasions. With the current HP I have no issues.
My questions are I have a stock bottom end:
1. Will it hold up to an occasional shot of 100/150 without doing any rod or rod bolt mods?
2. Are there other issues or mods I should know about?
3. Everything I'm told & read tells me the transaxle should hold up to 800 RWHP. Is this also true of the engines bottom end? With a 100 shot I should be around 670 RW & with 150 around 710 RWHP.
Thanks guys.
Old Feb 23, 2017 | 09:37 AM
Unreal's Avatar
Unreal
Why not just spend $80, drop a pulley size and get same effect safer and at a fraction of the cost?
ls3s are typically solid till 800-900rwhp with solid octane/tune.
Transmission depends on which one you have (auto vs manual) and how it is used. If it is a show car that rarely sees power, should have no drive train issues.
If power is your goal, much better ways to do it. If it is a show car and you want the n2o for bling and to look cool, just accept that and do it. Can't hurt anything if you don't use it and keep bottle empty.
Old Feb 23, 2017 | 11:04 AM
Don4220's Avatar
Don4220
Cruising
Thanks Unreal for all the great info. I am going after the WOW factor for at car shows but I also want to be able to advertise the HP at 900. However I could not do that unless it actually had 900 HP. I also may use the n2o on very rare occasions. Also I would have it tuned.
Again thanks Unreal
Old Feb 23, 2017 | 11:14 AM
Unreal's Avatar
Unreal
IMO, it is far more impressive to have "900hp" without n2o.
Plus, saying you need 900hp to claim 900hp goes against all normal car show rules. You claim whatever you want. Even saying you have 750hp now is a big stretch with 590rwhp. All you can claim is 590rwhp. Applying an old school percent drive train loss to get crank HP has been disproven time and time again. 590 to 750 is a 25%+ estimated loss.
My car dynoed 1200rwhp, but I don't tell people it makes 1500hp.
You will have to address fuel system to up your numbers unless you run a dedicated n2o fuel cell so there is no additional load on the fuel system.
Old Feb 23, 2017 | 12:51 PM
Don4220's Avatar
Don4220
Cruising
Thanks for the info from your original reply it was helpful.
Anyone that knows anything about car shows and displaying mods knows that BOTH HP & RWHP is most always displayed. As for car shows rules it is pretty stupid to display info that is not true because when you get called out by someone that knows what they are talking about you either flat out lie or you explain what you have. I am not a liar and I've been one to call people out. As for a fake n2o setup I am not going there.
As for car show experience and awards comparisons I am not going to go there either.
Have a good day!
Old Feb 23, 2017 | 01:05 PM
Unreal's Avatar
Unreal
Just adjust your drivetrain loss to get to 900hp. Since that number is just made up anyways. Go one pulley smaller, make 650rwhp, and then say 900hp. See it all the time.
Old Feb 23, 2017 | 05:24 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
It can be done but your tuner better be on point..... 100-150 is high on a forced induction car already. 75 shot will prob gain you 125+HP... If you need anything let me know. You arent too far from me.
Old Feb 23, 2017 | 06:26 PM
Boomer111's Avatar
Boomer111
Kaboom....
Sorry OP just could not resist.
My feeling is to be better prepared and do it right, build up the drive train and engine parts.
The built engine specs look sexy too.
On the cheap , well looks cheap. Just saying when reading the car's specs at the show.
Either way good luck and have fun.
Old Feb 23, 2017 | 07:47 PM
Detoxx03's Avatar
Detoxx03
With proper fuel and tuning it can be done. I've been doing it for years.
Old Feb 23, 2017 | 11:52 PM
AIR_RAM's Avatar
AIR_RAM
Again thanks Unreal
I know a few guys who just mounted two chrome N20 tanks in the back with the hoses tucked away and not hooked up anywhere... They where just for show.
I agree with the pulley swap... In the end it would be more reliable and you would never run out of it...
Good luck with what ever you chose.
SPEED SAFE, NICK
Old Feb 24, 2017 | 05:07 PM
NJ_phil's Avatar
NJ_phil
LS3 @ 10.7:1 CR on boost with a 150 shot?
Trust me, there's more to worry about than the bottom end.
You'll have to de-tune it so much to avoid detonation I doubt you'll gain 50hp at the wheels.
Just go with a 50 to get the bling factor and save your pistons.
IMO...
Old Feb 28, 2017 | 10:49 AM
Gxpz06's Avatar
Gxpz06
Thanks guys.
Like Fran says below.... If you want the power curve grumt for race days and bling for show days the Nitrous is for you., then again you're adding 30lbs to the car and only 75hp.. so if just HP numbers then just take it to Fran to up the boost.,, ls2/3s are Really tough when tuned by expert and i've seen few out of his shop pushing 8xx Rwhp stock bottom end.,,
Ill take my gxp or ss to him to get that treatment WHEN I can stop buying cars and make one of them badaSS
Old Mar 31, 2017 | 07:05 PM
Don4220's Avatar
Don4220
Cruising
Default Bottom End Limits
Hello Frans96ss,
I would like to discuss this further with you if you are available, how and when and I get in touch with you.
thanks
To Bottom End HP Limits
