ECU or Pcm reflash?
Old Mar 1, 2017 | 03:12 PM
ColbeeLord's Avatar
ColbeeLord
Default ECU or Pcm reflash?
Hello everyone! I just got done installing a new air intake and long tube headers onto my A6 base. Now, as I expected, I have check engines codes for the upstream and downstream for the o2 sensors and the difference in flow through the catylitic converter. Does this get fixed by a PCM reflash? Or is there something else I have to get done? Thanks to anyone who responds.
Old Mar 1, 2017 | 04:02 PM
Unreal's Avatar
Unreal
Yes, a pcm/ecu flash will fix this.
Old Mar 1, 2017 | 04:55 PM
ColbeeLord's Avatar
ColbeeLord
Alright, thank you very much !
Old Mar 2, 2017 | 11:37 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
As Unreal says, but it involves more then just disabling the codes.
Old Mar 2, 2017 | 09:11 PM
BlindSpot's Avatar
BlindSpot
What codes did you see?
Old Mar 4, 2017 | 03:07 PM
449er's Avatar
449er
CF Community Team
You also need to get the car tuned because it may be running in a lean condition after the header install
To ECU or Pcm reflash?
