Key FOB Battery
Old Mar 9, 2017 | 05:39 AM
Detroit1's Avatar
Detroit1
Default Key FOB Battery
Recently had a problem with key fob not being recognized for a brief moment.
When I opened one of them, I found the battery to be #2025 instead of #2032. Looked it up in owners manual and also noticed that inside the FOB it even says 2032.
Did a quick search to validate and there are posts regarding this. One is a little thicker than the other, however it does fit.
I bought the car used, so I did not know how old the batteries were in the FOBS. Good idea to change out these once a year.
Thought I would re-post this topic as a reminder .
JB
Old Mar 10, 2017 | 08:13 PM
bassman50's Avatar
bassman50
JB
The CR2025 is a little thinner than the CR2032 and has a lower current rating, from what I've read. I would use the 2032 - - it will last a little longer.
Steve
Old Mar 10, 2017 | 08:28 PM
cclive's Avatar
cclive
2025 is 20 x 2.5 mm and 2032 is 20 x 3.2 mm...the lack of thickness might make the contacts a bit intermittent. 2032 is the most common of the lithium coin cells.
To Key FOB Battery
