What make and model did you replace your OEM balancer with
I have a 2010GS and wanted to know What make and model did you replace your OEM balancer with and where did you order it from?
SteveDoten (03-23-2017)
Innovators West. Quite possibility the best balancer out there, and certainly the best customer service. They're pricey, but well worth it, IMHO.
ATI Super Damper H/P 7.5
Part number ATI-917246
$489.00
$489.00
ATI with and ARP bolt.
Pricey, but done and over with. Nice knowing I will never deal with this issue again with these parts.
Summit Racing
Trick Flow Track Max TFS-19005
$189.97 +free shipping
GM OEM bolt ~$6.00 (Why use a $30 ARP bolt if you never have to replace it again?)
Will be taking on this project this weekend.
Cruise-In VII Veteran
Great thread, I just picked up another C6, this one a 2005.
Crank pulley was swapped October 2015 by the GM dealer, I drove it back from the car hauler (from FL) and didn't feel it was safe to drive.
On my list of replacement next week.
Powerbond 10% Underdrive Pulley from http://www.hinsonsupercars.com/p-860...u1117ss10.aspx
You also have the option of ordering either a GM bolt or ARP bolt with your order.
Thanks everyone. I'll probably be getting this done in the next month so I'll have to check out the options.
Power Bond Underdrive
purchase mine from Jegs couple years ago.prolly same as summit or the trickflow balancer.8rib setup and pinned it since Im supercharged now.and use a ARP bolt.
Ignovators West here came with it's own bolt is pinned and comes with keyway this thing never gets loose or out of wack rebuild able & high rpm happy.
I can't say about 40k miles later but so far the Powerbond pulley has lasted longer than the other GM balancers that it replaced.
Dmd71 (03-25-2017)
