Tsb help
Old Apr 3, 2017 | 08:13 PM
C6z51661's Avatar
C6z51661
6th Gear
Default Tsb help
Hi I have a 2007 corvette with a p0420 code there is a tsb for the car the dealer wanted to charge me 125 for reflashing the ecu even though there is a tsb on the car. Am I getting ripped off i thought they were free. And also do shops do that work also?tsb (technical service bulletin)
Old Apr 3, 2017 | 09:30 PM
RicK T's Avatar
RicK T
The TSB only applies to the LS7. The cost you were quoted seems pretty normal since your car is out of the 8 yr/80,000 mile emission warranty period.
Look through this thread, the TSB is in here but without the original number:
https://www.corvetteforum.com/forums...-cat-code.html
Old Apr 3, 2017 | 10:47 PM
C6z51661's Avatar
C6z51661
6th Gear
ok, so for the ls2 the tsb isn't available? Also if there is a tsb can it be done outside the dealer?
To Tsb help
