Ground hooked to 12volt help !
Old Apr 8, 2017 | 08:52 PM
corvetteoshawa's Avatar
corvetteoshawa
6th Gear
Default Ground hooked to 12volt help !
Hi guys I was dropping in a new motor in my c6 , and somewhere along the way we hooked ground wire 106 to the big post on the starter side . The car went to get fired fuel pump primed and battery was dead . So then new battery out in . Hit the start button fuel pump primed starter did not start because when power went through the starter solonid it back fed that ground . The ground was put pack onto the block . No fuses or relays were blown . When I tried to start it hooked up the correct way the dash goes black when the start button is relaed the dash lights come back on . Hooked up the scanner and it says uo100 lost communication with pcm/ecm a ? Just wondering what my next step is or it anyone has done the same ,? Thanks
Old Apr 10, 2017 | 10:24 PM
rabrooks's Avatar
rabrooks
im just guessing but the computer may need to be reflashed to previous setup
Old Apr 11, 2017 | 06:37 PM
irok's Avatar
irok
bump
Old Apr 11, 2017 | 09:18 PM
BrownVette's Avatar
BrownVette
I'd try leaving the battery unhooked for a while then trying again. If not, you probably have a bad ECM, did you check the ECM fuse in passenger side compartment?
Old Apr 11, 2017 | 09:20 PM
corvetteoshawa
6th Gear
Ya all fuses are good we put a meter on the harness that goes to the computer it has power and ground .
Old Apr 11, 2017 | 10:41 PM
BrownVette's Avatar
BrownVette
[QUOTE=corvetteoshawa;1594508825]Ya all fuses are good we put a meter on the harness that goes to the computer it has power and ground .[/QUOTE
check to make sure both (+) are hooked up to starter, one from alternator and one from battery. And make sure the purple wire is hooked up to starter too
Old Apr 12, 2017 | 07:00 AM
irok's Avatar
irok
bump
To Ground hooked to 12volt help !
