can't unlock my corvette
Old Apr 20, 2017 | 02:27 PM
garyt47525's Avatar
garyt47525
2nd Gear
Default can't unlock my corvette
Can you help? My FOB is not unlocking my car.
Old Apr 20, 2017 | 02:31 PM
Travlee's Avatar
Travlee
take the key out of the bottom of the fob, and insert into lock by the license plate to unlock... you can then pop the door from the hatch area
Old Apr 20, 2017 | 07:06 PM
HOXXOH's Avatar
HOXXOH
The only thing known about you is that you are a male and you can't get in your car.
Help is much easier if you fill out your profile and identify your car. Then when you ask questions, be more specific about the problem. In this case, knowing what year and model identifies the fob. How long you've had the car, if the problem is the passive or active entry, if this has been a random or occasional issue, recent battery problems, or anything else that might suggest a change, are just some of the information that leads to a quicker and more direct resolution.
To can't unlock my corvette
