Which fuel injectors
Old Apr 30, 2017 | 08:44 PM
badazz81z28's Avatar
badazz81z28
Default Which fuel injectors
looking for 60lb for an LS7. Seems there are some as low as $175 to thousands. Which ones do I need?
Old Apr 30, 2017 | 08:55 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
IMO either use a factory GM injector or I've had good luck with ID. Both have solid data to go along with them
Old Apr 30, 2017 | 10:37 PM
badazz81z28
There are factory 60 pounders?
Old Apr 30, 2017 | 10:43 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I thought ls9's were that big but they aren't, so nevermind on that option
ID850's then
Old May 1, 2017 | 03:49 PM
redbird555's Avatar
redbird555
Why do you need 60s? More info would help. Ls9/lsa injectors work fine and are 52-56lb depending on who you ask. Unless you're running boost or e85 those should be fine
Old May 1, 2017 | 03:52 PM
Unreal's Avatar
Unreal
LS9, then step up to ID850/1050x if ls9 are not enough.
Old May 1, 2017 | 06:56 PM
badazz81z28
Will LS9 work? I was told they were spray on stern specific for FI
Old May 1, 2017 | 07:05 PM
Unreal's Avatar
Unreal
Work for what? You haven't answer what the application or power goals is.
Yes, ls9 injectors will work for most applications, as long as they are not too small.
Old May 1, 2017 | 09:20 PM
badazz81z28
Is that relevant to my question? It's an LS7, cammed and worked heads. About 650 gross HP
Old May 1, 2017 | 09:33 PM
Unreal's Avatar
Unreal
Yes, it is relevant. LS9 may work perfect, or be way too small.
To Which fuel injectors
