Battery Replacement
Old May 10, 2017 | 04:13 PM
02 VETTER's Avatar
02 VETTER
Default Battery Replacement
I just put a New Car Battery in my 2012 G/S and NOW I get a Dic Reading that says NO-Fobs Found. Tried using the Manual and can not seem to get Past Acc. Mode ON . Never says WAIT or Counts Down 10
Minutes. I Put Fob in Glove Box and Turned the Key in Back 5 Times ??
NOTHING SEEMS to WORK !! The Car Locked Me in Twice and Emergency
Alarm went OFF a Couple of Times . I am Getting Really a Little Hot Over This !! Last Fall it Alarmed with US in it and had to Use the Pull-Tabs to
Get-Out. That is Why I Just Installed a NEW Car BATTERY . My Wifes'
Flob Usually Works when Mine Doesn't !! But NOW it won't and Takes 5
MINUTES of Constant Trying Just to Get-in-the-Car. Should not be This
difficult to get-in and START Your CORVETTE . Why Should I have to Pay
a DEALER $100.00+ to RE-PROGRAM the FOBS just for Battery Change.
Oh Yeah , I did Put NEW Batteries in the FOBs ALSO !! Thanks,02 VETTER
Old May 10, 2017 | 05:32 PM
HBsurfer's Avatar
HBsurfer
It is always possible the new battery you bought has been sitting on the shelf at the parts store for a long time and may not be fully charged. If you have a tender or charger, try charging the battery. If not, take it back where you bought it and have it load tested.
Old May 10, 2017 | 06:01 PM
timd38's Avatar
timd38
I agree, may have gotten an overage battery.
Old May 10, 2017 | 08:57 PM
Cherokee Nation's Avatar
Cherokee Nation
First check the DATE on the battery for when it was made....Good Luck
Old May 11, 2017 | 08:46 AM
EVRose's Avatar
EVRose
I agree with all of the above. And fyi, you never have to reprogram a fob. They don't lose their memory...ever.
Old May 11, 2017 | 10:15 AM
Bailegb's Avatar
Bailegb
The first time I had the same problem, I inadvertently put the FOB battery in backwards. Had to check the wife's FOB to figure it out,
To Battery Replacement
