2013 Corvette Passenger Door Window Switch
Old May 10, 2017 | 04:36 PM
sksongwriter's Avatar
sksongwriter
Cruising
Default 2013 Corvette Passenger Door Window Switch
I just purchased a 2013 Corvette with 13k miles on it and the passenger window switch does not work. Are these switches known to fail? The car is only 4 years old with low mileage, so it has me questioning the quality of the switch a bit.
Old May 12, 2017 | 03:35 AM
User Omega's Avatar
User Omega
I would pull the switch from the door and make sure that it is plugged in.
You can get a replacement pretty cheap. If it got water into the switch it could have corroded the internals.
Also inspect the wiring where it passes trough the door. There have been cases of damaged wiring there but with so few miles I would find that one hard to believe.
Old May 12, 2017 | 07:37 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
It's an electrical component. They can last for 30 years or 30 minutes. I agree with Omega, pull the switch and check the connections. With the power on, check for current at the connector then you know if it is the switch or a deeper problem.
Old May 12, 2017 | 07:55 AM
Dcasole's Avatar
Dcasole
Does the window work with the driver side switch ?
If so then the chance that it is just the switch is pretty high ....its a slim chance that it is anything else ..... switch is cheap ..
Dave
To 2013 Corvette Passenger Door Window Switch
