Brembo Brake Packages
Old May 11, 2017 | 08:21 AM
Xplosive Performance's Avatar
0Xplosive Performance
Former Vendor
St. Jude Donor '13
Default Brembo Brake Packages
CHEVROLET CORVETTE C6 Z06 | GRAND SPORT FRONT 6-PISTON MONOBLOCK | 350X34 MM (13.8") | 2-PIECE DISCS TYPE III SLOTTED ONLY
(F) 6-Piston Cast Monobloc Calipers | 350x34mm (13.8'') 2-Piece Discs | Complete Axle Set | Pre-Assembled | All Necessary Hardware Included
Caliper
Caliper Body: Cast Monobloc Radial Mount
Caliper Piston Configuration: 6-Piston
Caliper Piston Design And Insert Type: Inner Pressure Seal / OEM Approved Dust Boot
Disc
Disc Type:
Type 3
Disc Material/Finish: Advanced High Carbon Alloy / Corrosion Resistant Plating
Disc Diameter: 350mm
Disc Width (Measurement): 34mm
Disc Air Gap (Measurement): 17mm
Disc Annulus (Measurement): 68mm
Disc Construction: 2-Piece Disc Assembly
Disc Vane Design (Measurement): Vented Curved 48 Vane
Disc To Hat Mounting System: Floating D-Bobbin with Anti Rattle Spring
Included Hardware
Brake Lines: Proprietary Brembo Stainless Steel Braided Brake Lines by Goodridge
Mounting Hardware: Brembo Engineered CNC Billet Caliper Adapters - All Necessary Hardware Included For Ease of Installation
http://www.xplosiveperformance.com/C...ly_p_2987.html
CHEVROLET CORVETTE C6- 6-PISTON MONOBLOCK | 350X34 MM (13.8") | 2-PIECE DISCS
Product Description:
Front or Rear System Shown: Front
Intended Use:
StreetTrackRace
Caliper Caliper Body: Cast Monobloc Radial Mount Caliper Piston Configuration: 6-Piston Caliper Piston Design And Insert Type: Inner Pressure Seal / OEM Approved Dust Boot
Disc Disc Type: Type 3 Disc Material/Finish: Advanced High Carbon Alloy / Corrosion Resistant Plating Disc Diameter: 350mm Disc Width (Measurement): 34mm Disc Air Gap (Measurement): 17mm Disc Annulus (Measurement): 68mm Disc Construction: 2-Piece Disc Assembly Disc Vane Design (Measurement): Vented Curved 48 Vane Disc To Hat Mounting System: Floating D-Bobbin with Anti Rattle Spring
Included Hardware Brake Lines: Proprietary Brembo Stainless Steel Braided Brake Lines by Goodridge Mounting Hardware: Brembo Engineered CNC Billet Caliper Adapters - All Necessary Hardware Included For Ease of Installation
http://www.xplosiveperformance.com/C...cs_p_3351.html
CHEVROLET CORVETTE C6 Z51 05-09 6-PISTON MONOBLOCK | 355X32 MM (14") | 2 PIECE DISCS FRONT
(F) 6-Piston Monobloc Calipers | 355x32mm (14') 2-Piece Discs | Complete Axle Set | Pre-Assembled | All Necessary Hardware Included
Wheel Fitment: How to Measure Wheels for Required Clearance
Brake Profile Cross Section
Intended Use:
StreetTrackRace
Caliper
Disc
Disc Type:
Cross Drilled
Slotted
Type 3
Disc Diameter: 355mm
Disc Width (Measurement): 32mm
Disc Air Gap (Measurement): 16mm
Disc Annulus (Measurement): 54mm
Friction Material
Pad Compound: Brembo High Performance FM1000
Pad Volume / Surface Area: 94.5 | 84
Included Hardware
http://www.xplosiveperformance.com/C...t-_p_3359.html
COMING THIRD QUARTER the NEW NEW GT-S caliper, NEW BM-4 caliper, NEW BM-6
The race inspired Brembo M6 and M4 calipers are perfect for the club racer or weekend track day enthusiast that wants to take that next step in braking. The M6 is a six-piston aluminum front caliper with performance properties gleaned from the company’s endurance caliper that helped the Ford GT win the 24 Hours of Le Mans. The pistons, with racing style radiators and no external dust seal, provide the best combination of performance and long-lasting track use. The calipers are hard anodized for longevity and resistance to corrosion at high temperatures. The Brembo logo is racing style, engraved in red, as seen on all of the company’s competition products.
The new six-piston M6 calipers and four-piston M4 are derived from the current Brembo Gran Turismo (GT) performance caliper family. This makes the new components fully interchangeable with the GT kits, allowing them to fit under the same size wheels and accommodate the same size rotors while providing increased performance. In fact, the M6 and M4 calipers can be referenced through the same application list as the GT brake systems.
The M6 is a front caliper designed for a disc that measures from 350 to 405mm, with a thickness of 32 to 34mm. The M4 is used for the rear axle as well as for some front applications and wraps around disc sizes from 328 to 380mm. The M6 and M4 share the same Brembo design characteristics that have been proven at the top rungs of motorsport for over 40 years.
Size:  35.4 KBName:  BREMBO-M6_1.jpg
Size:  59.0 KBName:  GTS.jpg
Size:  15.2 KBName:  image003.png
Old May 15, 2017 | 08:38 AM
Former Vendor
St. Jude Donor '13
Old May 17, 2017 | 08:33 AM
Former Vendor
St. Jude Donor '13
Old May 22, 2017 | 08:37 AM
Former Vendor
St. Jude Donor '13
Old May 24, 2017 | 12:46 AM
HC Mechanic's Avatar
HC Mechanic
Very nice
Will those rotors work with my Z06 calipers by any chance?
Old May 24, 2017 | 07:46 AM
Former Vendor
St. Jude Donor '13
Originally Posted by HC Mechanic
Very nice
They will not if your looking for a 2 piece gas slotted front rotor with aluminum hats use
http://www.xplosiveperformance.com/G...O6_p_4062.html
Old Jun 26, 2017 | 09:57 AM
Former Vendor
St. Jude Donor '13
Old Jun 26, 2017 | 11:14 AM
HC Mechanic
Originally Posted by Xplosive Performance
Really like this color combo, what do you call it?
To Brembo Brake Packages
