Tire Size Question, Please Help ASAP!
Now my question is on the front, I am going with NITTO NT05 275/?/18 tires, I think. These are my questions and choices. I can go with a 265/35/18 tire, or a 275/35/18 tire or a 275/40/18 tire. Stock front Z06 tires are 275 so I am leaning toward that. The question is do I go with 35 or 40?
The 35 is @ 25.5 inches tall which is what my Michelin are now. The 40's are @ 26.5, about an inch taller than my current size and the 35's.
So my question is this, should I go with 275/35/18 or 275/40/18 on the front. My car is low to the ground but not lowered so the extra inch would help, but then again, in performance, closer to the ground is better so the 35's would be better.
I have a tuner that can make any necessary adjustments if there are any, so no issue there.
Can anyone with specific knowledge tell me if I should do the 35 or 40 and why, and what is the advantage or disadvantages.
Thank you all in advance for all your help, you guys are always helpful.
Also, the tire Brand and Type is not in debate, only asking for help with the profile size and why one is better than the other if any difference at all, thanks again.
Rick
