2009 diagnostic
Old May 12, 2017 | 09:00 AM
cinor's Avatar
cinor
Default 2009 diagnostic
How do you clear the diagnostic codes on a 2009 corvette. mechanic had his scanner on it but couldn't get the codes to clear
Old May 12, 2017 | 10:31 AM
Kenny94945's Avatar
Kenny94945
Odd IMO...a scanner will typically remove/ erase codes.
Unless, the code is constant and keeps coming back.
So, what code remains?
Old trick is to disconnect the battery's negative cable for 5 minutes.
Then reset radio windows etc.
Or try another scanner?
Good luck.
Old May 12, 2017 | 08:19 PM
Dcasole's Avatar
Dcasole
Need more info what was the orginal problem ?
So what are the codes?
Did ur mech fix the problem ?
Do the codes go away and come back ?
To 2009 diagnostic
