Recently picked up a 2013 427 Convertible. LS7 dry sump.
Decided to change my own oil. Did a bit or reading first. It actually went well I think.
I warmed it up first.
2 drain plugs. Dropped the OEM filter.
10 Quarts came out!
I used a K&N wrench on filter. MOBLE 1 synthetic.5W30.
Oil pan Had the car level on jacks.
put 8 Quarts back in. Warmed it back up.
nothing on the dip stick.
added 2 more Quarts. Seems ok.
is the K&N filter ok for the LS7?
any outher points of note would be appreciated.
10 Quarts came out!
thank you.
Personally I would use the factory filter - I don't believe the K&N has the same micron filtration specs, and the cost is a wash. I also believe you can just run the car up on ramps and get almost all the oil oit -- it's not like the old C5 where it needed to be level. And --- at least you had a large enough drain pan -- an embarrassing mistake on my first oil change.
You actually have to raise the rear if you want to get all the old oil out. Especially in the LS7 with the 2 plugs.
Also, agree on the oil filter. Stick with OEM or go with WIX. I use WIX, much cheaper than Mobil 1 but just as much, if not better, protection and performance.
Here's how I change my oil:
I noticed you have 8 Quarts of oil in yours. To get proper level on my 2013 dipstick I need 10 Quarts
I put 8 in. Ran it. Checked it. Nothing on the stick. I needed themail last 2.
Technically you are correct about having the LS7 level to get ALL the oil out. But by doing it on ramps (not level) you only leave a couple of ounces of old oil which is negligible over a 10 qt fill. It's not like the C5 with the baffled oil pan which retained a lot more oil if not changed while level. That's why I don't bother leveling my C6 LS7 when changing the oil.
In the OP picture post if the old filter was OEM Delco and BLUE in color I suspect it was wrong. If you look up the OEM spec I believe it should be the BLACK color and the part number ends in R.
I have a GS Dry Sump with 10 quarts of oil and two drain plugs. Realize it is LS6 and not a 7 like yours. These cars run at higher oil pressure and need a filter that can handle it. Believe the Mobil 1 and K&N filters are both higher pressure.
When I did the oil change in my video, not much oil came out of the side drain plug when the rear was not raised. Once I raised the rear, way more than a few ounces came out the side plug!
To each their own, though. It only takes an extra 2-3 minutes to raise the rear, and if it means getting almost every drop of oil out, then it's worth it to me.
The K&N box mentioned that the filter was suitable for high burst pressures.
I had suspected that there had been a change in oil volume through the years. I wish the owners manual had addressd the fluid capacity more directly. They seem to dance around the subject. Unless I missed it.
