Opinions needed, quick!
Old May 17, 2017 | 10:25 AM
ChrisUlrich's Avatar
ChrisUlrich
Default Opinions needed, quick!
I have a 2008 C6 Coupe with Z06 brake upgrade.
how does everyone like Stop Tech rotors with Wagner Brake Pads?
or is there a better option out there?
Old May 17, 2017 | 10:57 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Better option as in pads or rotors? What are you using the car for?
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old May 17, 2017 | 12:09 PM
ChrisUlrich
No road course stuff.
But for racing, mostly. I want the car to stop from high speeds without locking up or issue.
Old May 17, 2017 | 02:45 PM
Carbotech Adam
Supporting Vendor
For pads I would look at these 2 options.
Carbotech™ 1521™
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
Old May 30, 2017 | 06:57 AM
ChrisUlrich
Anyone have any reviews on Carbotech stuff?
To Opinions needed, quick!
