NEED HELP please!
service active handling light comes on
crusise control does not work
my brakes lights are ON when NOT braking and OFF when braking???
I was orignally guessing this this could be a wheel speed sensor because of the cruise control and active handling, but wtf is up with the brake lights?
Any help would be appreciated. I am baffled, as electronics aren't my forte. Thanks in advance!
How do you check the voltage regulator? And alternator is putting out 13.9 to 14.1 volts according to my DIC. (And let's face it, I've got a smart DIC 😂😂😂
sorry I'm 13 when it comes to jokes.
I've been reading through my service manuals and the electrical schematics show that the stop lamp signal and TC switch/ light all run through the BCM while the brake fluid pressure sensor, yaw rate sensor, and lateral accelerometer all run through the EBCM.
I hope and pray that it is not a wheel speed sensor as they are integral to the hub assembly and bearings and must be replaced as an entire hub assembly unit. YIKES!
Still shooting in the dark here so any thoughts are appreciated. I'm like the Ray Charles of mechanics. I can't see sh$t so I just keep feeling around in the dark until I find something that sounds good. LOL
As someone who works for an auto-manufacturer...loose couplers are the biggest electrical problems in cars.
Any recommendations on OBDII scanners? Is one as good as the other? I'm looking at one on amazon called a Foxwell NT201 scanner.
Here is one that has input to the ECBM, the Brake Pedal Position Sensor.
Here are the symptoms of a bad input from the BPP
The brake pedal position sensor (BPP) is an input to the electronic brake control module (EBCM). The brake pedal position sensor is a potentiometer type sensor with a 5-volt reference circuit and a low reference circuit. The body control module (BCM) supplies the 5-volt reference to the BPP.
This is the DTC that somewhat describes the rear brake light function.
C0161 12
Possible causes of this DTC are the following conditions:
A signal circuit of the brake pedal position sensor is open.
The brake pedal position sensor needs recalibration.
All brake lamps are open.
All brake lamp grounds are open.
An internal brake pedal position sensor malfunction.
The other conditions that you are experiencing (service active handling light comes on and cruise control does not work)
is symptoms of other DT codes that are associated with the ECBM, mostly CO110, etc. There are many more that have the same symptoms, pertaining to an input to the ECBM, ot the ECBM itself.
You mentioned that you did see a service manual, so you must be seeing the symptoms that I have read.
The one thing that you can do for free, is to check the connector at the ECBM. The connector could be loose, or not sealing properly.
That is one of the primary checks when doing a diagnosis in troubleshooting.
Of course if that doesn't stop the conditions, then indeed a wheel speed sensor could cause the symptoms that you describe.
DTC C0035 LF Wheel Speed Sensor Circuit
DTC C0040 RF Wheel Speed Sensor Circuit
DTC C0045 LR Wheel Speed Sensor Circuit
DTC C0050 RR Wheel Speed Sensor Circuit
This is the symptoms of a bad wheel speed sensor
The EBCM disables the Antilock Brake System (ABS)/engine drag control (EDC)/Traction Control System (TCS)/tire pressure monitor (TPM)/Vehicle Stability Enhancement System (VSES) for the duration of the ignition cycle.
The adaptive cruise control (ACC) braking function is disabled.
The DRP does not function optimally.
The ABS indicator turns ON.
The traction control indicator turns ON.
The drive information center (DIC) displays the Service Stability System message.
Good Luck
Maybe you get lucky and a connector at the EDCBM was the culprit.
If you need the Antilock brake service section via PDF, PM me your e-mail and I'll send it to you.
It's too large to post on here.
Im getting a scanner just for future use.
Now here's the screwy part. I did the Nintendo fix (disconnect blow it out and reconnect) the ECM blue cables in the passenger footwell and now the problem is gone. I have done two test drives and everything seems to be functioning normally. I'll definitely be keeping an eye on the ECBM in case it happens again.
Im just very very happy it doesn't appear to be the wheel sped sensor.
The BCM connectors (blue) in the foot well can get pushed a bit by a passenger, and this has been known to cause all kinds of weird and wonderful symptoms. Some owners have used pencil erasers as spacers so the footwell panel cannot touch the BCM connectors if the panel is pushed by a nervous "braking" passenger.
Hopefully, your issues will not return, but if the same ones do, undo the connectors, and spray a contact cleaner at the connectors for the pins and the female portion as well, on both the ECBM and the BCM connectors. This will assure a good contact.
Really, having a code reader that can indeed read the ABS, Air bag system, etc. can come in handy when troubleshooting. It can narrow it down to what input is causing the issues.
Good Luck
Good Luck
Good Luck
I put my scanner tool on the car and have zero codes being shown so everything appears to be back to normal. What codes are you throwing?
2006, M6,Z51,3LT
