Technical tire question
May 20, 2017 | 01:57 PM
I’m looking at swapping out my Michelin Cup’s with the newer Cup 2 version
The current size on the car is - 325/30/19
The new Cup 2’s come in both a 315mm and 325mm width versions of that tire.
Would there be any performance advantage going with a 315mm on this wheel size?
My concern is with the 325, the sizewall is stretched quite a bit; not sure how that affects the tire dynamics.
Thanks in advance for your wisdom
May 20, 2017 | 02:58 PM
The tires should have an ideal rim width listed for each size. If they're 12" wide rims, I would stick with the 325s. If any narrower, they will stretch the 325s.
May 20, 2017 | 03:02 PM
Quote:
Originally Posted by
Patriot Six
Sorry, forgot to mention the wheel size - 19 x 11’s
May 20, 2017 | 03:07 PM
I would stick with the 315s so you don't stretch them.
May 20, 2017 | 03:14 PM
Just spoke with JBSBlown about the street tire he runs, as all his cars have loads of power.
He advised the R888
After doing some research it looks like they have a new “R888R” tire in a 305/30/19, or the previous model “R888" in a 305 or 325mm width.
May 20, 2017 | 03:21 PM
I would go with either before Cups. The R888Rs look promising.
May 21, 2017 | 03:19 PM
2017 C5 of the Year Finalist
St. Jude Donor '08
HC Mechanic
He advised the R888
Nice chatting with you, and yes. I'd go with the R888R in the 305/30/19, the recommended rim size is 11", so that should work GREAT.
May 21, 2017 | 03:38 PM
jbsblownc5
Sounds great Joel, I'll do just that
Running low on my octane booster as well, do you have a link to order?
Bought so much last round I forget where the heck you told me to get it..
