Random misfire problem, help needed please..
I'm getting a hesitation on hard acceleration, but not on smooth acceleration.
Tech2 log looks ok for most PIDS i.e STFT and LTFT all look ok, mostly on the -4 range
under deceleration it goes into OL and O2's drop to 0 which i believe is normal.
on the misfire data i'm getting random cylinder misfires but no codes.
i'v attached a screenshot as the one thing that concerns me is the spark readings......40deg!!!
I dont know much about Spark advance and retard and have tried to search for normal spark readings for an LS2
but cant find any info.
Can someone point me in the right direction of what spark readings i should be getting on a non modded standard LS2 C6?
BTW where i live the fuel from the gas station is 95 RON and 98 RON. i use the 95.
Remember that several of the PIDS pulled off the OBD connector are "calculated and not representative of real values. PIDS such as AFR, fuel pressure.
Only thing I see that causes any question on my part is bottom right corner. Warmups since DTC cleared 7 counts and warmups without Emission faults. What DTC?
I needed that because i had seen figures of total spark of 27deg and seeing 40deg made me look towards ignition for my hesitation/misfire condition, so will look towards maybe a fuel delivery issue as my next tests.
Cleared DTC's were to do with seat restraint system and a couple of HVAC issues, no engine DTC's at all since iv owned the car for the last 12 months
Cheers
This will give you a snapshot of the variety of spark advance at any moment in time. As I've told you before, it is very difficult to analyze engine management status on snapshot screens. I have a Tech II as well, and if you really have misfires, in the rpm range, the tech II will record it.
I will run a few misfire data logs tomorrow and see what RPM's they are occurring.
BTW - simply looking at a spark table doesn't tell you the whole story by a significant amount. There are SEVERAL spark modifier tables that influence the final spark the engine sees. This spark table is the basis from which the modifiers are applied for numerous reasons. Just to name two modifiers - IAT and KR.
BTW, I know you've been chasing these random misfires under acceleration for a while now. Something that is a little off the path you might want to check is fuel pressure. Here is where the Tech II is not going to help you BC that PID is not actual fuel pressure but calculated.
You might want to get a gauge on the end of the fuel rail and get a real FP reading under different RPM and acceleration situations. Verify that FP is not falling off when needed the most. A weak pump or a dirty screen off the pump in the tank can cause that.
Your on the money about the fuel pressure being an avenue to check out.
Ive got a full fuel tester (with schrader) arriving on Thursday so will be checkin FP through rev range as my next diagnostic now you've helped me clear up the ignition query.
Focus on Relative Throttle position as a percentage. Relative Throttle, Commanded Throttle and Actual Throttle are all different, but for a hypothetical, let's just say that commanded and relative throttle are the same thing:
With that, here are two hypotheticals - Let's put you in a C6 with a manual trans:
Scenario #1 - Start from a dead stop in first gear, accelerate all the way to redline while holding a commanded throttle of 30% the entire time.
Scenario #2 - Start from a dead stop and accelerate all the way to redline, only this time, commanded 100% throttle the entire time.
In these two scenarios, the ECM is going to take different paths along the X and the Y axis to get from idle RPM to redline RPM.
Now you can begin to think about cylinder air mass as the volume of air allowed to enter past the TB's butterfly valve and into the cylinders, as a charge, at different RPMs and different TPs. The vertical column will start to make some sense. BTW, deceleration, along with fuel cutoff (DFCO) also takes it's own path on the table going back to idle.
To your question, the Tech II won't provide much and will do nothing to analyze the spark table, but I agree with Schpenxel ign adv has nothing to do with your issue, just satisfying your curiosity about the 40* adv that you saw. In HPT however, you can use a spark adv graph in a datalog and track the path the ECM took.
