MAF Compensation Q
Old Jun 10, 2017 | 03:59 PM
2L8LUZ's Avatar
2L8LUZ
Default MAF Compensation Q
Hey Gang,
I have noticed lately that my cam miss has been a bit more than usual lately... a bit more of a miss feeling than normal...
So I decided to check the plug wires for loose connections...it seemed like one of the wires going to a coil was a bit loose and snapped into place more than it was...
While doing all of this I decided to clean the maf... in the process of this ...I noticed that the clamps holding on the CAI to the TB had come loose...not overly loose but I don't believe that they were 100% sealed prior to tuning...
I cleaned the maf... re-secured all of the clamps and took her out for a test drive.... it seems that normal not WOT driving seems to be considerable less responsive and slower than normal...
My Q is this....
I know that the MAF will compensate for up to 25% differences... If there were any leaks.... should the maf compensate for this?
Or should I reset the fuel trims??
Thanks...
Old Jun 10, 2017 | 05:58 PM
BlindSpot's Avatar
BlindSpot
MAF doesn't compensate for anything. It reads the airflow past it and the ECM uses that reading to fuel. If additional air enters into the air flow past the MAF then that is unaccounted for and will add to the air in the AFR.
Fuel trims can correct a lean condition up to 25% then report the problem in a CEL.
How/why are you going to reset fuel trims?
Old Jun 10, 2017 | 06:13 PM
2L8LUZ's Avatar
2L8LUZ
I'm going to pull the ecm fuse
Thank you for the feedback...
Old Jun 10, 2017 | 06:22 PM
BlindSpot's Avatar
BlindSpot
Fuel trims are self-correcting, that's what they do. If you pull the fuse, you'll start over, true, but will not correct anything. Assuming by reading your first post, you think the car might have been tuned with an air leak? The tuner tuned in an air leak? That could be a problem, if so. Correcting the air leak now will change fueling depending how the tuner set up the fuel. If the car has a MAF only tune, then yes, you'll especially have a rich fueling issue.
Old Jun 10, 2017 | 08:06 PM
2L8LUZ's Avatar
2L8LUZ
Ya,,,adjusting the tune comes next week...I was just curious on the MAF compensation
Old Jun 11, 2017 | 08:16 AM
Unreal's Avatar
Unreal
As Blindspot said, there is no maf compensation. Fuel trims can compensate up to 25%, but they also are based off narrow band o2s, and won't trim negative at WOT or read at WOT properly, so it won't adjust it properly for PE. It will apply positive trims at WOT, but if you clear those, and then go around beating on it, the car could be extremely lean.
At idle/part throttle fuel trims can adjust for some changes, but should never be relied on to do that.
Old Jun 11, 2017 | 01:07 PM
2L8LUZ's Avatar
2L8LUZ
No i get it....I know WOT is going to be off....I apologize for the terminology...I was speaking to the fuel trims compensating...
To MAF Compensation Q
