LS3 Headers Spark Plug Insulators
Old Jun 16, 2017 | 05:00 AM
Detroit1's Avatar
Detroit1
Default LS3 Headers Spark Plug Insulators
Have ARH Long Tubes and what appears to be OEM Spark Plug wires.
The headers are not coated so I do have concern over plug wires even though I do not notice any exterior melting etc. This is on a 2011 GS.
Anyone added these "socks" to their OEM wires and recommendation on which ones to use that will fit.
I see a bunch of various post and some recommend just getting a cheaper pair from Amazon. I am fine with that as long as they will provide adequate protection.
Thanks in advance for your advice.
Jim
Old Jun 16, 2017 | 05:19 AM
WW7's Avatar
WW7
I have a set from Advance Auto on both of my cars and they do the job.. Most brands seem to be about the same quality......WW
Old Jun 16, 2017 | 11:32 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I bought those $17 ones from amazon last year and I can't imagine any other brands being better. They haven't turned colors and aren't coming unraveled and you could buy multiple sets for what some people are charging.
Old Jun 16, 2017 | 05:47 PM
Dcasole's Avatar
Dcasole
here are mine ...
Dave
Old Jun 16, 2017 | 07:07 PM
timd38's Avatar
timd38
I have the same one as above and have had zero issues in 10 years.
Old Jun 19, 2017 | 09:12 AM
rhoyvald's Avatar
rhoyvald
I got mine from Hinson via amazon and they work well.
View this post on Instagram
Old Jun 19, 2017 | 09:29 AM
LoganExplosion's Avatar
LoganExplosion
I've never ran these and never melted a wire. Not sure why they're so popular now.. Are you peoples' plug wires flailing around??
Old Jun 19, 2017 | 09:34 AM
rhoyvald's Avatar
rhoyvald
The only reason I got these is that #4 spark plug wire was too close to the header tube (actually melted a bit - replaced and installed these sleeves) and didn't want to put just one sleeve on the one plug wire. Plus I think they look better and are a cheap mod.
Old Jun 21, 2017 | 02:32 PM
R_W's Avatar
R_W
https://www.instagram.com/p/BSZkLPOgL1Z/
Same. Small price to pay for peace of mind in the face of melting wires.
Old Jun 21, 2017 | 03:27 PM
HOXXOH's Avatar
HOXXOH
Running the OEM wires at 145K miles. The last 65K with LG headers. Maybe the brand of headers some people have don't have enough clearance.
Old Jun 21, 2017 | 03:44 PM
Detroit1's Avatar
Detroit1
Default Thanks for all the input
Jim
Agree that one of mine is a bit closer to the header. Don't see any damage at this time and just want to avoid future issue.
Checking out the various ones you guys have recommended and will be ordering some this week.
I believe that some header designs put the plug wire close to the openings. Just observed this on a friend's car where he installed a used set from a vette owner. Don't know if the ones he went with were specific to his year and that might be the reason why they are so close.
As usual all you fellows provide good advice.
Regards,
JB
Old Jun 22, 2017 | 06:16 AM
Unreal's Avatar
Unreal
Agreed. Had a set, ran them for a month or so, I think it actually made it worse, so went back to factory.
The factory melt heat shields work great.
Old Jun 23, 2017 | 05:29 PM
Not So Fast's Avatar
Not So Fast
I did the MSD wires and DEI boots while doing the headers, is it necessary, I don't know but while I was at it I did it, looks "COOL" anyways
NSF
Old Jun 25, 2017 | 03:44 PM
cstapp99's Avatar
cstapp99
NSF
If I'm looking at your photo correctly, the locking tab on the header bolt just in front of the #6 header tube is on the bottom of the header pipe. It needs to be on top of the pipe. Just a heads-up.
Old Jun 25, 2017 | 05:16 PM
Not So Fast
It was corrected in the final check list Good eye in fact 2 were wrong, damn buddies fault
Plus 2 of those little springy clips were lost, man do they fly, but Stage 8 was great in replacing anything I screwed up
NSF
Old Jun 25, 2017 | 06:26 PM
cstapp99's Avatar
cstapp99
NSF
I'm glad I'm not the only one. Love the stage 8 fasteners, but I also had a couple of brain farts when I installed them on my headers.
Old Jun 25, 2017 | 08:44 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agree. Stock wires and shields. Two of mine are damn near touching and they've still been fine so far on mine. Adding something like a sleeve would just be touching and seems like it'd make things worse
To LS3 Headers Spark Plug Insulators
