Auto transmission leak
Old Jun 19, 2017 | 11:36 PM
Jstch00tme's Avatar
Jstch00tme
5th Gear
Default Auto transmission leak
Can anyone tell me what this 11mm bolt is for?
Mine was backed out, but not loose, and leaking. I tightend it up and it stopped leaking. But from all the pix I have found it looks like its supposed to be out a little.
Old Jun 20, 2017 | 01:18 PM
HOXXOH's Avatar
HOXXOH
IIRC and without looking in the SM, it's the port to check the pressure.
Old Jun 20, 2017 | 06:14 PM
Jstch00tme's Avatar
Jstch00tme
5th Gear
Default Thanks
If you have the service manual would you mind looking it up and verifying, and tell me if it's supposed to be completely closed and if so what the torque setting is?
Old Jun 21, 2017 | 12:44 AM
HOXXOH's Avatar
HOXXOH
Line pressure plug is correct.
The torque spec is 97 lb. in.
That's just a smidgen over 8 lb. ft. aka not very much.
Old Jun 21, 2017 | 10:02 AM
Jstch00tme's Avatar
Jstch00tme
5th Gear
thanks again much appreciated!!
To Auto transmission leak
