Seat Memory Position
Old Jul 2, 2017 | 05:48 PM
Yellow95's Avatar
Yellow95
Default Seat Memory Position
I just figured I would let the forum know about my fix for my memory seats.
My seat would not properly find the proper position, sometimes. It would move but would stop before it got to the right spot. If I moved it some more with the seat button it would move. I could then press the door button again and it would continue to the proper position.
I figured it was a problem with the seat position sensor connector but I didn't know how the seat worked. I finally got fed up and took out the repair manual and took a look. the sensor is attached to the motor under the seat. I took out the seat, disconnected and reconnected the connectors several times and then put the seat back in.
All is fine now. Just a bad connection.
I hope this helps other folks with the same problem.
