I just cannot let go of the numbers i got when I had my car dynoed. This guy is probably the best when it comes to Corvettes in Sweden, and i trust him, but i know there are LOTS of high quality tuners in America and around the world.
Whats your thoughts? Graph looks like it should?
K&N CAI
Fast Lsxr intake 90mm TB
BTR Stage 4 cam
Stock heads (new valves, seals, guides, rockers etc)
Kooks 1 7/8 headers
Akrapovic 3" x-pipe and titanium exhaust. De-Cat
Granatelli spark plug wires
Quite a lot of bucking / surging 1200-1800 rpm.
Will head to him and try to lessen the big amounts of surging within a week.
Could removing the intake/radiator shield cause it to surge more than it should with this cam?
Any tuning input or advice is much appreciated,
Thank you!
Have you checked to see if the CAI Throttle-body clamps were tightened enough? You can't just use a Flat-head screw driver to tighten these....it requires a small socket wrench and squeezing them down as much as you possibly can...
All of my bucking/surging went away after I did this.... Check and then reset fuel trims and see if there is a difference... You will be able to tell immediately... It can be a simple mistake overlooked by the shop...
This would also result in lower HP numbers as the intake is not getting all its possible airflow...
If you think that the clamps are tight enough...Tighten more...
Are you getting slower power results in the 2700 to 3800 rpm range and then it picks up around 4k??
I'm betting money on this!
Thanks, I will check those clamps.
Ive done pretty much everything on this engine myself, except install the cam, that was done by the previous owner.
Reset fuel trims using HP tuners or ?
Thanks again!
Are you experiencing low HP from 2200 to 3900 rpms?
Thanks, and happy 4th!
Well, the car feels sluggish from low rpm until about 4k where both power and torque increases, also shown in the graph in my first post. Its not as crisp in the lower RPM range compared to when the cam is really put to work.
I was thinking add timing during lower rpm to get a bit more punch, but it seems you remove timing to lessen the surge.
Even very little amounts of timing down low would still give you a crispness...
After you tighten the clamps back down you will be rich.... which is just fine..because u get all your power back and restore your low rpm acceleration.... just have your tuner take more fuel out to get you to optimal range
It's not too much timing...this is your problem..id bet my left arm on it...
The bucking/surging ...gave it away
Its no big deal to tighten down the clamps more and reset your battery...
It won't effect the tune...
This WILL solve your problem
Im sorry, but this was probably not the cause. Everything was clamped down real tight, and there are no leaks around the intake or any vacuum hoses.
We've now added some timing at low rpm's, and the engine responds better, but sadly with more bucking/surging. In 2nd gear the bucking is causing an increase/decrease of 200rpm. Will go back this week and try some more.
Thanks 2L8LUZ!
Did your tuner reset fuel trims after securing? Did u also check air filter clamps?
If you fixed the air leaks and just added more timing without resetting your bucking and surging will be even worse as described...
Indeed i used a ratchet to properly secure the clamps. They were already really tight from when i installed them, so i couldn't really tighten them more.
There were no air leaks evident, and I reset the ECM and he did have a look at the fuel trims. Don't know i he reset them, or just tweaked with the added timing. Isn't everything reset when flashing the new tune?
A stage 4 cam is going to buck/surge at light throttle <2k. That is part of having a big cam. Without driving the car, hard to say if your car is normal or if it could be improved with tuning.
No.... The answer is Yes/No... The changes put in place change factors but doesn't adapt to driving habbits...It takes 250 miles for that to fully adjust...the car will act differently around 100 or so miles after new tune is flashed...
keep driving it... if your problems still occur locate a new tuner....I know nobody wants to hear that..
I can cruise in 6th gear at 1200 rpms with no issues
Yeah, indeed it will. Ill probably have the tuner go back more toward the old tune with less timing, since it behaved better then with regards to buck/surge.
Thanks!
Sadly, Its kind of hard finding another tuner in Sweden. There really are just a few guys doing these cars, spread across the country. And he's probably one of the best. I think my feedback might not be up to par though since I'm very new to this.
Thanks!
Here's a possibility... I know its a far stretch but its the little things that you can mark off your checklist... Have you ensured that your plug wires are secure and haven't backed off either the plug or coil ?? This will cause that as well... Check to see if they are snapped in place... The plug wires will be over the plugs but with cams this size my comes off all the time..
Its not that far of a stretch. Found one that was a little loose this last weekend when going over things in the engine bay.
Now they are all secured properly. The Granatelli wires require 2 clicks to be heard on the coil side, and 1 click on the spark plug side. Didn't help though.
I've come to find out that with this cam I have to check wires everytime I wash the car... It isn't hard for them fall off with all that shaking
