Standard or underdrive pulley? HP difference?
Old Jul 4, 2017 | 02:09 PM
DDP's Avatar
DDP
Default Standard or underdrive pulley? HP difference?
I'm changing the wobbly crankshaft harmonic balancer and pulley and was contemplating putting on an underdrive pulley. Is there a benefit?
Old Jul 5, 2017 | 01:34 PM
2L8LUZ's Avatar
2L8LUZ
I personally feel that the 5-10 hp difference isn't worth the lower voltage levels..
Old Jul 5, 2017 | 02:42 PM
mbowers13's Avatar
mbowers13
From: https://www.facebook.com/groups/OrangeCorvettes/
I have the ATI UD balancer and at idle the voltage is a little on the low side but works great other than that.
Old Jul 6, 2017 | 11:24 AM
HOXXOH's Avatar
HOXXOH
Unless you already have most of the other performance mods and are looking for that last .01 second bump in your 1/4 mile time, there's not a benefit for a UD pulley that outweighs the negative for your electrical system.
Old Jul 6, 2017 | 01:40 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agree, I would not do an UD pulley on these cars. They're already borderline (at best) at having enough amperage at idle to run all the electronics and fan in particular
Old Jul 6, 2017 | 02:16 PM
grady's Avatar
grady
Would the electrical issue of the UD fully be offset by a higher amp alternator?
Old Jul 6, 2017 | 02:17 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It certainly wouldn't hurt, though I always wondered if the higher amp units were more difficult to turn or not, which would negate some of the gains. In the end it just doesn't seem worth it to me.
Old Jul 6, 2017 | 02:33 PM
DDP's Avatar
DDP
I've decided to go with a standard aftermarket harmonic balancer and pulley. Thanks for all our input.
Old Jul 7, 2017 | 11:46 AM
Orion2011's Avatar
Orion2011
It solved my low amp issue with my otherwise stock car...
To Standard or underdrive pulley? HP difference?
