random rolling a/f ratio?
Old Jul 24, 2017 | 08:02 PM
Joe Wendell's Avatar
Joe Wendell
Default random rolling a/f ratio?
2007 Z06 heads, cam, intake, exhaust. I have notice at warm start it takes up to 30 seconds for the car to get to around 14.7 on my a/f gauge. It will hover around 19.1 (general number but lean) and slowly work down. I am not really worried about this , maybe I should be IDK.
My concern is sometimes when coasting to stops it can change either way. I have seen it slowly go up to 19.1 or even back to the 13.1 range and stay lean or rich for up to 30 seconds. After which it will go back to normal. Any insights? Thanks in advance. Joe
Old Jul 24, 2017 | 08:53 PM
Dano523's Avatar
Dano523
Your pulling your numbers after the cats.
at less than WOT and crusing, the ECM should be holding the A/F at 14.7, and at WOT, should be around 12.5~12.7; both of which are pre-cat numbers.
Hence at less than WOT, the system is running closed loop, then at WOT it goes into open loop instead.
Also at start up, the heaters in the O2 sensors are powered on, and this give kind of a funky reading until the O2 heaters are shut off once the car warms up to get a real reading of what the motor is doinig.
Old Jul 24, 2017 | 09:30 PM
Joe Wendell
Thanks for the reply, I should have posted no cats and W/B sensor is in the original rear O2 location. All readings I am seeing are actual in relation to what the A/F ratio is. 99% of the time it is 14.7 cruise/idle, 12.8 Wot minus dfco
I don't no if the tuner changed the start up A/F for hot start conditions or why.
My real concern is the random coast down issue. Either I have a bad sensor, failing fuel pump, or power draw from unrelated component, etc.
I ran the HPTuner on one occasion only to see the cars 02's go flat during an episode. all temps normal, battery good, no other signs or lights.
Just thought I would ask the question as I am puzzled. Thanks.
Old Jul 25, 2017 | 10:22 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Normal. Sensor probably isn't heated up yet when you're getting the lean readings at start up. It isn't going to hurt anything even if it is correct
The spikes to 19 during decel is probably deceleration fuel cutoff.. normal
Old Jul 25, 2017 | 10:23 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
No...
Old Jul 26, 2017 | 05:04 AM
Unreal's Avatar
Unreal
As Carson said completely normal. Afr moves around. Depends on open or closed loop, dcfo, warm up tables, etc.
Old Jul 28, 2017 | 01:13 PM
Orion2011's Avatar
Orion2011
It will be in open loop using the VE tables till the engine warms up. (normal)
Adjusting the VE table up a bit could bring this closer to 14.7
When coasting the CPU can shut off the injectors showing a full lean condition (normal)
Make sure you wideband is not after your cats.
To random rolling a/f ratio?
