Clutch Resevoir Cap?!
This is important to replace since its enlarged, correct??
Thanks!
That part number is correct.
http://www.wholesalegmpartsonline.co.../19208898.html
No reason to replace it...push it back to flat and add some DOT4.Last edited by cclive; Aug 2, 2017 at 10:20 PM.
Pull it from the cap, push the inner piece up farther up, then push the center back down to add a second fold to it.
Here is what is should look like with the two folds,
what do do you mean by "inner piece up farther up?"
It pushed all the way in to get the first fold at just before the top of side ribs,
Now making the second inner fold before putting it back it the cap.
As for once you have it folded correctly and in the cap, when you install it into into the tank, it should snug to the sides of the tank to prevent air from leaking through the sides.
In this photo, your past the outer fold line since the outer fold line is past the side ribs, and have not push the center back down to get the second inner fold line.
Incidentally, brake fluid is kind of nasty. It is a potent paint stripper so try not to get it on things like your car's bodywork or that laptop. Fortunately it's hygroscopic, so you can wash it off with water.
When the new cap arrives, use a turkey baster to suck out all that used fluid that's been absorbing humidity for the last week and refill the reservoir with new stuff.
If the game plan is to do the ranger fluid change, then that can be first down without the rubber diapham in the cap (you just the cap for that).
As for when you are going to install the cap with diaphragm correctly folded (using the old one), then squeeze the diaphragm bottom fold sides in to get it started in the tank with the fluid to the full fill line, then you can use the cap to press the rest of the diaphragm into place tight against the top of the fluid in the tank. The diaphragm will take its old shape in a week of two once it in the tank.
Note to point out, you can install the diaphragm in the tank without the cap, then install the cap to the diaphragm when you installing it on the tank.
Hence even a new diaphragm will be tight to the sides of the tank. The way that the diaphragm works is is holds tight to the sides of the tank, and its seated to the top of the fluid in the tank. As the fluid lowers in the tank, the diaphragm will unfold to lower down to keep air from reaching the the fluid isntead.
Hence the tank was low of fluid for a long time to cause the diaphragm to slightly distort, or someone did not know how to fold the diaphragm correctly, and why it in the shape it is now.
https://www.youtube.com/watch?v=gBbsy0LjUvE
Im not sure why the F for mechanic skills...I was just simply showing you the issue with the diaphragm. I'm going to try a new cap and I'm hoping that cap comes with a new diaphragm? The value on my diaphragm isn't working correctly now at all because it won't stay in the diaphragm. I just bought the car a few months ago so I can't say who or how the diaphragm could have been folded. I appreciate your help!
Hence this is a dead give away that who ever did any servicing on the vet before they tried to sell it, does not have a clue, and makes you wonder what else they may have missed when servicing the car to get it ready for sale.
Since I think that you the one that just got the vet, try to find a seasoned vet owner that can do a once over on your car to see if anything else may need be corrected as well. Hence if the clutch fluid looks that bad and was not corrected, then bank that the brake fluid is long over due for a power flush as well (should be power flushed about every 3 years).
Also, pull the vin number up on the GM recall site, and see if there are any outstanding recalls that need to be done to the car for free as well.
https://my.gm.com/recalls
